Brushless water pump
/ Brushless water pump #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I'm looking for a 12v brushless water pump that'll do around 5 gpm and put up about 60 psi, typical of ones you guys would use for sprayers on your tractor 3 ph.
Cannot seem to find a source.
I'd like it to pump out of a little stream up to my rain tanks. I've some diaphragm pumps with brush motors that work but don't last very long on a battery charge. Brushless should go much longer.
Thanks.
Ralph
Not much help. Went on Agri Supply and Northern Tools sites and contacted them. No reply yet.
Ralph
/ Brushless water pump #4
My neighbor has two remote cow watering stations. They both have 12V, solar powered pumps. I think they are "Red Jacket" by brand. Simple float controlled operation. Lift is 15 feet or less. He had to put the float controls inside a 18" diameter vertical pipe to keep the cows from "jamming the works".
Otherwise - they operate from spring thru fall. I know the local deer & elk sure appreciate these watering stations also.
Around here a watering station is every bit as good as a food plot.
/ Brushless water pump #5
I have a Shurflo pump for my sprayer that's worked great, but I only use it a couple days in the Spring, and a couple days in the Fall. The rest of the year, it sits outside with my sprayer tank. It's not what you are looking for, but it has been a good pump and maybe a starting point for something bigger that you are wanting?
https://www.amazon.com/Shurflo-2088...1YFSZGMP4W3&psc=1&refRID=5V6QBBGAV1YFSZGMP4W3
Finally just ordered one off Amazon, as we had some points there. Cannot find brushless pumps except for aquarium ones.
Strangely enough, on any pump where it tells the operating amps, they're lower than what one would calculate for the pump flow & head and even 100% efficiency on the combined motor and pump. Diaphragm should be the most efficient. I calculate 12 amps for a 3 gpm/60 psi pump on 12v at 95% efficiency. Think I need to buy a backup marine battery to match what we have on our gate to get much running time (e.g. higher amp-hour). Don't think the little utility battery will last very long and be worth my time connecting it and all. The 3 gpm will fill my tanks in about 6 hours; so, a 72 amp hour battery is needed.
Ralph
/ Brushless water pump #7
Could have gone with a 110 volt pump and an inverter, even though I must say, I don't like inverters. Possibly any inefficiencies in the inverter might be made up by less circuit resistance to the pump, depending on layout.
Also, I have considered taking a high quality gear pump, or other style and then joining it to the DC motor of my choice. 12 volt pumps have always been stupid expensive and not of high quality either.
/ Brushless water pump #8
If you are running the pump off a battery and don’t have an automatic low voltage (say 11.5 volts or so) kill switch that would explain the short pump life. You will smoke the thing in no time at low voltage.
Didn't know there was such a thing. Will look into it.
Figured out why their quoted amps are lower than what I calculate. Gotta be using about 14 volts. Yeah, as voltage drops, the amperage would go up to maintain the same pump flow/head. Think what happens is the motor slows down though.
Ralph
/ Brushless water pump #10
If you set up solar panels and a charge controller, you won't have to haul the battery in to charge it every day.
/ Brushless water pump #11
Ralph
One word- heat!
The new pump with a new marine battery are working fine. Should run for 8 hours, as the battery is 95 amp hour. Very quiet. Will see where the levels in the 3 tanks and 4 barrels connected together end up before one overflows, if that happens before I shut the pump down at about 6 pm. Also pumping into the soaker hoses of garden and raspberry patch.
Each pumping period should give me 3 to 5 days' worth of water by switching among the tanks and barrels.
Ralph
Well, spoke too soon. The pump apparently quit.
I've near a quarter mile of 3/4" poly pipe down to it and haven't used about 1/2 of it for 3 or 4 years (haven't needed it). Found a leak and suspected maybe another; so, cut the line where it ran underneath the tractor crossing and reconnected just before the crossing to the other side.
Then could not get the bloody pump to work. Took it back up here to the house and thought I had it going again. Still would not pump. Going to send the pump back for a refund. Cannot take it apart. The screws have VERY soft heads and use a driver type that I don't have. Loosened all but 3, but they would not budge and rounded them out a little bit. Figured the bigger 3.0 gpm pump would be more foregiving of most stuff.
Got out one of my old (US made Flojet) 1.8 gpm ones. It worked in pumping from a nearly full bucket sitting beside the pump. Took it down, but it would not pump up the approximately 18" to the pump sitting on the tractor crossing. Figure I've a very tiny air leak on the suction side. Will simplify what I have on the suction and try it again tomorrow. Got another old Flojet 1.8 gpm.
Think my neighbor has the right idea. He put in about a 2 or 2 1/2" poly line from the creek up to his house with a motor driven pump, about 50 gpm: MUCH more forgiving a slight leaks on the suction side. Much bigger project.
Ralph
I've about concluded that diaphragm pumps (did not ever run into them in refinery work I did as a chemical engineer; dealt with pumps a lot) are absolutely no good for drawing UP on the suction side. They're made to suck from gravity tanks that are usually at the same level with liquid higher than the pump until suction is near empty. Also, very clean service: not sucking from a flowing stream.
I got the sorry pump working sucking from a bucket on the pavement and pump elevated in the FEL. Took it down to the stream: NOTHING.
I'll take it apart tomorrow. This US made pump has nice stainless steel screws holding it together, not the very soft metal ones the Chinese one had. (Wife sent it back by UPS today.)
Think what I need is a small reciprocating pump. Don't seem to make any small ones. A small centrifugal would chew up too much battery juice because it would not be very efficient.
Ralph
/ Brushless water pump #18
Your best bet is probably a submersible pump. No vacuum. The little vacuum pumps rely on rubber/neoprene internals (diaphragm or vanes). A submersible doesn’t. Might be time to invert and use 120v pump.
Think all submersible ones are centrifugal. The smaller ones (like the ones our the old power steering systems) only do about 30% efficiency. That's about 3 times the amount of juice a positive displacement pump driver would need. The inverter would burn some more juice in losses.
Ralph
/ Brushless water pump #20
A diaphragm pump being 3x as efficient as a submersible centrifugal pump simply isn’t the case.
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
2022 New Holland Boomer 45 (A64911)
2022 New Holland...
JMR QA Work Basket (A64912)
JMR QA Work Basket...
WALK OVER LADDER (A68842)
WALK OVER LADDER...
2019 Kubota M5-091 (A64911)
2019 Kubota M5-091...
KOMATSU D31PX Blade / C-Frame (A68134)
KOMATSU D31PX...
