Cub Cadet 3206 too Slow
   / Cub Cadet 3206 too Slow #1
GTSRider
Gold Member
Cub Cadet 3000
I have a 3206 Cub Cadet, which I am happy with, with the exception of it being too slow.
I guesstimate about 3mph..... getting this figure from my 2017 Craftsman (MTD) , Rated at 5MPH.
Transmission filter and Cub Cadet fluid has been done, but still painfully slow.
Is there an adjustment on the 3000 series to make them faster moving ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 3206 too Slow #2
The pedal adjustment is a balance between forward and reverse speeds. The faster you adjust it for reverse speed the slower the forward speed will be. I had a 2004 3235 which I adjusted for the minimum tolerable reverse speed to get the maximum forward speed. When it still seemed too slow I made a modification to allow further forward pedal travel which helped. If you search for my posts a few years ago you will find a description and photos.
Bob B.
Bob B.
Thanks Bob....I will try what you said.
Thanks,
Pete
   / Cub Cadet 3206 too Slow #4
Try reaching down and pulling up on your reverse pedal. If you experience a sizeable amount of speed in reverse, then yes-you need to adjust the balance for the forward and reverse take-up. If its slow, too. Check if you have and play in the linkage or bushings underneath. I have a 3205, myself.
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
Self Dumping Hopper (A53316)
Self Dumping...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
CAT PS-150C (A53314)
2008 Blue Bird School Bus (RUNS)(TITLE) (A50775)
2008 Blue Bird...
