Cub Cadet 3206 too Slow
   / Cub Cadet 3206 too Slow #1
GTSRider
Cub Cadet 3000
I have a 3206 Cub Cadet, which I am happy with, with the exception of it being too slow.
I guesstimate about 3mph..... getting this figure from my 2017 Craftsman (MTD) , Rated at 5MPH.
Transmission filter and Cub Cadet fluid has been done, but still painfully slow.
Is there an adjustment on the 3000 series to make them faster moving ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 3206 too Slow #2
The pedal adjustment is a balance between forward and reverse speeds. The faster you adjust it for reverse speed the slower the forward speed will be. I had a 2004 3235 which I adjusted for the minimum tolerable reverse speed to get the maximum forward speed. When it still seemed too slow I made a modification to allow further forward pedal travel which helped. If you search for my posts a few years ago you will find a description and photos.
Bob B.
Bob B.
Thanks Bob....I will try what you said.
Thanks,
Pete
   / Cub Cadet 3206 too Slow #4
Try reaching down and pulling up on your reverse pedal. If you experience a sizeable amount of speed in reverse, then yes-you need to adjust the balance for the forward and reverse take-up. If its slow, too. Check if you have and play in the linkage or bushings underneath. I have a 3205, myself.
TURN PLOW (A57192)
TURN PLOW (A57192)
2023 KOMATSU PC55MR-5 EXCAVATOR (A52707)
2023 KOMATSU...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2024 FORD F250 SUPER DUTY BED (A57880)
2024 FORD F250...
