Cub Cadet 3206 too Slow
   / Cub Cadet 3206 too Slow #1
GTSRider
Cub Cadet 3000
I have a 3206 Cub Cadet, which I am happy with, with the exception of it being too slow.
I guesstimate about 3mph..... getting this figure from my 2017 Craftsman (MTD) , Rated at 5MPH.
Transmission filter and Cub Cadet fluid has been done, but still painfully slow.
Is there an adjustment on the 3000 series to make them faster moving ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 3206 too Slow #2
The pedal adjustment is a balance between forward and reverse speeds. The faster you adjust it for reverse speed the slower the forward speed will be. I had a 2004 3235 which I adjusted for the minimum tolerable reverse speed to get the maximum forward speed. When it still seemed too slow I made a modification to allow further forward pedal travel which helped. If you search for my posts a few years ago you will find a description and photos.
Bob B.
Bob B.
Thanks Bob....I will try what you said.
Thanks,
Pete
   / Cub Cadet 3206 too Slow #4
Try reaching down and pulling up on your reverse pedal. If you experience a sizeable amount of speed in reverse, then yes-you need to adjust the balance for the forward and reverse take-up. If its slow, too. Check if you have and play in the linkage or bushings underneath. I have a 3205, myself.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2024 Hydraulic Trencher Skid Steer Attachment (A55851)
2024 Hydraulic...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
UNUSED FUTURE FT-YLJ100 HYD TRACK PIN PRESS MACHIN (A57193)
UNUSED FUTURE...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
