Oil & Fuel JD 318 stops running
/ JD 318 stops running #1
Sissybitus
Crossville, TN
John Deere 318; 1987
1987 JD 318 Onan Motor. Will run for 20 minutes, then just shuts down. Wait about 15 minutes and it starts up again and then does the same thing.
/ JD 318 stops running #2
When it shuts down have you checked for spark. maybe the coil is heat failing.
Thank you, I will check for that. I had thought it might be the new gas cap, it didn't have a vent, so I put on a vented cap, but haven't had a chance to test drive.
/ JD 318 stops running #5
All good guesses for symptoms.
- Coil
- Bad tank vent
- Fuel line either getting too hot (vapor lock) and/or
- Fuel line weak enough that it collapses and pinches itself (is this possible?) .
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
Kubota L4740 Grand L HST Cab Tractor
Kubota L4740 Grand...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
