Sickle Bar Dearborn 14-15 on new tractor
/ Dearborn 14-15 on new tractor #1
JRaw83
Chillicothe, OH
Mahindra 1533
Hi all, I recently picked up a Dearborn 14-15 7 sickle bar mower for $200. I have the manual and I致e been looking it over, it appears that there is supposed to be a bracket on the right hand side. I have a Mahindra 1533 tractor, I thought this would just be a standard 3-point hookup but now I知 wondering if I知 over my head. This is my first go at this and I知 finding myself learning a lot of lessons the hard (expensive) way. Any help on how to hook up is appreciated, the manual only references hooking up to a 8N/9N style tractor.
/ Dearborn 14-15 on new tractor #2
Your Mahindra 1533 has a standard Category 1, Three Point Hitch.
The Ford 8N/9N also have a standard Category 1, Three Point Hitch.
Your Mahindra 1533 is close in dimensions to the Ford 8N/9N.
You should be able to figure out how to mount the mower if all the mower parts are there.
Do you have experience mounting other Three Point Hitch implements?
/ Dearborn 14-15 on new tractor #3
Stop by Mike's Farm Equipment, there North of town. He's located almost directly across from the entrance to Great Seal State Park. He can answer about any question you may have on it. He's been dealing in new & used equipment for years, and is, I'm sure familiar with the mower you have. Great place to buy aftermarket parts, and has a meager amount of used equipment around there. Great guy to deal with, and will treat you right.
/ Dearborn 14-15 on new tractor #4
There's a bracket that clamps to the right side 3pt arm. It creates another pin to fasten the trip mechanism to. I'll try to get a pic of mine today.
Yes, I知 pretty adept at most 3-point hookups, this breakaway bar has me stumped though. I can稚 seem to find a way to attach it since I don稚 have the original bracket. Was hoping that someone had some experience with this particular model. I don稚 have a lot of tools for fabricating, unfortunately either.
I know where Mikes is, I値l try to swing over there and talk to him. I forgot about his shop. Thanks :)
That would be great! Thank you!
/ Dearborn 14-15 on new tractor #8
Are you talking about the anchor brackets that attach to the tractor? IMG_1108.jpg
/ Dearborn 14-15 on new tractor #10
You only need one, depends on the setup, but yours would need a right hand side bracket. For yours it will not be a bolt on part, you will have to hook up the three point and then see were the arm ends up on your tractor and fab a mount for it. I’m not sure what your talking about as for a stabilizer on the left side.
/ Dearborn 14-15 on new tractor #11
If your talking about this pin that I have circled, that’s were your left hand lift arm mounts. IMG_1111.jpg
/ Dearborn 14-15 on new tractor #12
That left bracket is a standard for those old Fords. They used them on both sides on the bottom of the fender bracket bolts and allowed for bars to be attached to those stubby pins (other end over the 3 point pin on the attachment). TSC still sells those generic bars, but you won't need it on the left since your Mahindra has it's own stabilizer.
/ Dearborn 14-15 on new tractor #13
There you go, a bit better explanation.
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
