An easier way to refuel your tractor
   / An easier way to refuel your tractor #181
2 mile drive
Way easier than cans
Andy
If there were all roads that had 45 mph or less speed limits I wouldn't mind doing this but since I only need a 5 gal can of fuel about once a month its not worth the safety risk.
   / An easier way to refuel your tractor #183
5 gallon can. Rest it on the hood, and pour.
   / An easier way to refuel your tractor #185
Exactly...should it be harder than this?
TXCOMT
I'd have to have 3-4' of extension spout, given the tank is behind the seat.......
   / An easier way to refuel your tractor #186
TXCOMT
5 gallons is 40 lbs. Lifting 40 lbs to shoulder level to put gas can on hood is risking injury. Using a cheap battery powered pump is much easier
   / An easier way to refuel your tractor #187
Yup back in the day I could take 5 gal of fuel and throw it over the tractor, but now It's just hard to get 5 gal off the ground let alone on tractor hood. So to over come gravity in later years, transfer pump is the only way for me.
   / An easier way to refuel your tractor #188
Oldpath05,
I hear ya.... I can 't swing those 5 gallon jugs around like I used to either.
It's extremely hard to hoist it on top of the hood in the middle of the tractor with the FEL attached.
I too, have started using a transfer pump.
It's true... when you get older, you really DO learn to work smart... not hard.
   / An easier way to refuel your tractor #189
Oldpath05,
Like tradosaurus mention, lifting 40 lbs at shoulder height on tractor hood can cause injury. Four years ago was the last time for me, it was one of those times when the brain made a contract that my body couldn't fulfill.
Theres been some very good links here on this thread on fair priced transfer pumps, so anyone here pushing 60 get one now cause I have some good news and some bad news for ya, the good news is that we get older, the bad news is that we get older..............
   / An easier way to refuel your tractor #190
I got tired of hauling the 5 gallon jugs and filling in the tax forms to recover the highway tak for farm use, so I finally bought a NEW 55 USG drum ($121), used manual pump ($20) and a drum lifter ($80) and made a chain attachement to unload from my pickup. There is a dyed diesel cardlock her in Milton ON, but you can not use 5 gal jugs as the nozzle is big truck size. The drum has a 2 inch opening. All works great! Tomorrow I am going to add an inline oil-water filter, just to be safe.
   / An easier way to refuel your tractor #191
TXCOMT
you would play heck trying to fuel 4 of my tractors in this manner - one fuels having to use a 6 foot ladder to get on top of hood, another from the rear of the tractor and behind the cab and it takes an 6-8 foot ladder to get up there while balancing on the ladder and tire due to its location for the spout so you have to pour it suspended, another fuels from the rear at shoulder height and the other at waist level behind the seat so c'mon over rockstars you can do all my fueling with your 5 gallon can for me anytime and i will humbly watch since its tough and my 80y/o dad cant do it either - we will gladly cheer you on!!! ;-)
   / An easier way to refuel your tractor #192
I made one with an inexpensive universal 12 volt fuel pump, battery, hoses. To make it easier you could find a convenient place to mount one on a tractor, each hose the right length coiled up out of the way, plugged when not used keep dirt out.
   / An easier way to refuel your tractor #193
Shared it before but this might work for some of you, you can get one on Amazon for just under $20 it is for diesel or oil empties a 5 gallon can in just under a minute with can on ground and my fuel inlet is between 5 and 6 ft from ground. I just connect it to a ground and the hot on starter because that is the handiest on my tractor.pump.jpeg
   / An easier way to refuel your tractor #194
Just an update remembered to time how long it takes with my pump 4 1/2 minutes for 5 gal not real fast but not bad.0905191455.jpeg0905191453.jpeg
   / An easier way to refuel your tractor #195
This is my 15 gallon storage and pump station. 3 different pumps, the orange one is my favorite. My fill is on the side and can be filled standing on the ground.
   / An easier way to refuel your tractor #196
As you can see in picture mine is on top almost eye level I'm 6'3"
   / An easier way to refuel your tractor #197
I have the same 5gal yellow one on the right same as you. And a red one for gas. Two modifications though. Added a vent plug just rear of the top handle for better flow, and removed (cut off) the 'safety' ratcheting mechanism that makes it a nuisance to remove the spout for refilling.
   / An easier way to refuel your tractor #198
I also have the exact same 5 gallon yellow jug on the far right. It is such a pain in the ***, lol! Pushing down that darn green button to dispense the gas while holding the jug 6 feet in the air is a pain.
   / An easier way to refuel your tractor #199
That's why I got the little pump in my pics just stick the hose in connect the leads pit other end in tank and turn it on
   / An easier way to refuel your tractor #200
Any volunteers to put over 40 gallons in this one, never could figure out why Deere thought it was a good idea to put the fuel tanks so high and difficult to reach.
Climb up the steps, then reach out with your foot for the top of the tire, then stand on the axle while putting in 30-40 gallons, and of course the engine and radiator is nice and warm too. :laughing:
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2017 Kustom Signals Towable Solar Radar Speed Limit Trailer (A59228)
2017 Kustom...
