Briggs and Stratton OHV - Stripped Spark Plug
   / Briggs and Stratton OHV - Stripped Spark Plug #11
There's an outside chance the spark plug had defect and was putting out a weak spark and causing the poor performance...also why it broke like it did ??
   / Briggs and Stratton OHV - Stripped Spark Plug #12
Hope this thread does no go on like the "rounded off drain plug" thread......
Only problem I have had with any B&S's are the stupid neoprene (rubber?) "O" ring they use for a needle seat in carb swelling up and not letting any fuel in... GRRRRR..... 20 cent part and our billion dollar alcohol fuel program screws it up........
Dale
12 posts in a only a short while... it could!
Actually - that would be bad. This motor is not worth too much effort. Just a good try before replacement.
   / Briggs and Stratton OHV - Stripped Spark Plug #14
I'm lost!
The title says it's a "stripped spark plug", now it sounds like it's not stripped at all!!
I don't know how anyone is suppose to properly answer something so confusing?
SR
   / Briggs and Stratton OHV - Stripped Spark Plug #15
I'm lost!
SR
By reading the OP's description would be a good start. It took me a couple of reads but then figured it out.
   / Briggs and Stratton OHV - Stripped Spark Plug #16
Change "striped" for "broken" and it reads fine.... Yeah my first though was threads in head were toast....
Dale
Dale
Sorry - for some reason it was in my head as a "stripped" plug when I wrote it. But its not, its broken at the threads, even with the head.
   / Briggs and Stratton OHV - Stripped Spark Plug #18
I'd take a propane torch, heat the plug, let it cool and turn it out. Get it fairly hot...
SR
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
Unused Delta Crash...
1240 (A50490)
1240 (A50490)
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
