4707
100% yes! But It did not even bend the blade. Compare to my old tractor that something broke almost even other time I used it.
I’m glad you like it! Using my commercially it gets a good workout daily and I’m still impressed with it. I’ve got mine dialed in and it’s cutting super clean.
There but for the Grace of God go I....wow that must have made a bang.
That's a mean IED...
glad to see there are more owners of this model. Really helps to compare notes and experience which gives you a sanity
check vs what the dealer may tell you or knows.
Adjusted my steering. 1 wrench, incredibly easy & quick...should have done this weeks ago. Used a sand rock pile to check clearance on each side.
Anyone know if most bolts on this tractor are metric or standard?
Then cleared a tree with the é¼*og loader ( I need a real grapple), this tractor is so great & useful! (Had to use a chainsaw too, not just that pole saw..)
All hardware on the 4700 Series is metric.
got my tractor back yesterday before the storms come today.
hydraulic top link installed plus rear camera system. Glad they put camera on super strong magnets, not sure why putting the camera off to one side makes sense, I'm moving back to the middle. Thankfully they said they left lots of extra cable inside. This is the least expensive of Agco's three approved camera system. Which I'm sure means I paid twice too much for it, but then they waived the install labor on it so I'm sure not going to complain. They also installed the camera lower in the cab than I would have liked. I have to fuss with it to get it dialed in. Camera comes with useless remote control with tons of functions that aren't even used. I adjusted one setting, to make it brighter, gosh nice I can do that with a remote control but talk about answering a question no one asked. Completely unnecessary complexity. Maybe it's a guy and his remotes thing...;)
Hey Daugen, do you know where the dealer tapped power for your camera system? Just curious what is available besides a cigarette lighter adapter.
no, I'll look next time I'm in it
I do find it interesting oem work lights do not turn off with key switch.
I tapped into mine by removing the pillar panel where the ignition is (just pull on it), and there was a dead headed wire that was only hot with ignition.
Thank you both. I got my 4707 last night. I will post pictures this weekend. Both of you have really helped me out!
Awesome. You wont be disappointed. Impressive machine.
No visio roof but I really like it so far. Very impressed with the quality and how much of a difference adjusting the steering stops made.
Mine was run behind the plastic around the corner from the throttle pedal. And they didn't leave me enough room to open the door far enough either.
How did you run the wires into the cab? Is there space in the rear roof? On the front, did you follow the wire loom in?
Congrats on the new purchase! I was looking at the 1760M but thinking of maybe jumping up to the 4707. If you dont mind me asking what did you end up paying out the door?
I ran all the camera wires to the back, then through the grommet under the rear window
52k. I did upgrade the loader to the fl3615 which is a 2500 upgrade. That also includes the front fenders, block heater and a radio.
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A68183)
Pemberton Inc...
PORTA POTTY (A68842)
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
