Zero turns with steering wheels?
/ Zero turns with steering wheels? #1
riverpro
Central MN
none
Just curious if anyone runs one of these? Looks like John Deere and Snapper threw in the towel on these and that leaves only Cub Cadet for current models. It's my understanding that turf tear is far less with these vs. lap bars. Not sure if that's true or not?? I have some "mild" slope on one side of my home which I'm sure a lap bar zeroturn would fair just fine but really want to avoid tearing up any grass on a new seeding lawn. Any info, experience, good, bad, and just anything you care to share would be greatly appreciated!! Thanks in advance for anything you can share!
/ Zero turns with steering wheels? #2
Not sure about turf tear but you can't beat a good ol steering wheel...
/ Zero turns with steering wheels? #3
Just no.....it's like kissing your sister. :shocked:
/ Zero turns with steering wheels? #4
Toro makes one. https://www.toro.com/en/homeowner/riding-mowers/timecutter-sw5000-74790
My 92 year old Mother still loves to mow. A couple of years back her tractor mower engine blew. The mower wasn't worth replacing the engine so I started searching for her a new mower. I personally run a conventional zero turn but I knew she would not like the stick control at her age. I found this Toro and bought it. She loves it and I have to say that it has impressed me. This mower will turn just like my zero turn. I have never noticed it tearing up the turf. It does great on slopes and leaves a nice cut (especially with the mulching kit I put on it).
It has been a great mower so far that has exceeded my expectations.
/ Zero turns with steering wheels? #5
A Scag we bought back in 1980ish times had a steering wheel.
Ralph
/ Zero turns with steering wheels? #6
The Cadets are a different system then the deere which had caster wheels on the front. the cadets use linkage to the rear wheels as well as the fronts turning with the steering wheel. They are the best hill zero turn we sell! Another part is anyone can drive them and they do help reduce lawn damage on turns. We have actually had people return the twin sticks to get the steering wheel units.
/ Zero turns with steering wheels? #7
The cub cadet system is different than anything on the market to my knowledge. I currently use a Toro Groundsmaster that has power steering and turns only the back steering wheels. The drive wheels just drive and do not pivot with the rear steer wheels. I get very little tear out in the yard and with the offset deck I can almost turn around 180 degrees and meet the uncut grass like a zero turn. I know that it is an odd booger but meets my needs very well.
Sorry, by mistake I mentioned snapper not producing these anymore but I meant Toro. Have a friend who owns a Toro dealer and they no longer offer these, although I just noticed TroyBuilt makes one but only one deck size.
LOL, I remember someone awhile back mentioning they feel Forrest Gumpish on one though!
Turby's that is one serious mower, front pto and all!
Thank you all who took the time to post!
/ Zero turns with steering wheels? #12
I guess that explains why is says "limited availability" in the link I posted. They are probably selling out the current inventory.
/ Zero turns with steering wheels? #13
Very nice commercial grade unit, no junk there!:thumbsup:
/ Zero turns with steering wheels? #14
Front deck mowers with a steering wheel is a different animal. Almost a zero turn. My old F725 John Deere is awesome.
The Craftsman ZT7500 zero turn I owned for a couple of years took some practice to avoid tearing up the turf. On top of that it would beat you to death.
/ Zero turns with steering wheels? #15
The longer wheelbase of those units help out with the ride. I really don't understand the appeal of a fast zero turn. My ground is so rough that speed is governed by terrain anyway. Size of deck cut to me is where I save the most time.
/ Zero turns with steering wheels? #16
can somebody explain how the cub cadets work with a steering wheel? Is the steering wheel just a hydraulic manifold that takes the place of the arm levers or does it actually turn steering tires?
/ Zero turns with steering wheels? #17
Mine is very rough also...these are interesting...…. IS(R) 32Z Zero Turn Mowers | Ferris
/ Zero turns with steering wheels? #18
mine bounces a lot too
/ Zero turns with steering wheels? #19
Mine is very rough also...these are interesting...? IS(R) 32Z Zero Turn Mowers | Ferris
We have a local Ferris dealer and he has been very successful. They are priced higher than most other units but utilize IMHO heavier duty bearings that are grease-able. Most all of the other units use sealed bearings. I find it interesting that Ferris has developed units without their proprietary suspension system to hit a lower price point.
Toro has addressed this ride issue with the new MY RIDE system but they still use sealed bearings which I do not like.
https://www.homedepot.com/p/Toro-Ti...Riding-Mower-with-Smart-Speed-75213/300949915
/ Zero turns with steering wheels? #20
When I was shopping around for a zero turn, the ones that I saw with a steering wheel where the lower end home owner models with a single hydraulic pump that runs both tires. The bigger commercial mowers all had two hydraulic pumps, one for each tire, and the handles directly control each pump. To me, this was a much better system.
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
