Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #5,861
OK, color me confused. After reading and reading and reading though this tomb of a thread on flails plus many hours of Google searches I decided I wanted one and after some time finally found a New Holland 918H for a price that was just to good to pass up. The mower is in what I would call very good shape, all the bearings are super smooth and it has only one small weld on a lift mounting ear and the blades, if that is the proper term, are worn but still have what I would consider a lot of life left but could be flipped if needed. They are the "Y" type.
Now on to my problem, the cut quality is what I consider to be poor at best. It is somewhat ragged and leaves the tire track uncut. I say tire track since it is setup as an offset. I tried to mow at 3" and at 2" which did not make any difference in the cut quality, of course the PTO is running @540. The skids are just slightly off the ground and it rides on the roller like I have read it should. The manual states it should be run between 4 and 6 mph ground speed, I have even gone as slow as 3 mph but still leaves the track. It will "almost make s smooth cut if I creep along. Currently the rotor is rotating clockwise as you look at the mower from the left/drive belt side as seated on the tractor, which is opposite the tire rotation. Is this the proper rotation or should it be counter clockwise, same as tire, so it would pickup the mashed down grass which is what I think would be better. However I tend to get into trouble when I think to much.
The gearbox can be configured to rotate in either direction with a couple of hours labor but you end up having to destroy one hard to get $25 seal. I have no problem doing the reconfigure but would hate to do it only to find out I should have left well enough alone. So what is the definitive answer about flail rotation? The more I have read about it the more confused I have become as nobody seems to use the same terminology when talking about the direction of rotation.
I really like not having the windrows of grass I get with a finish mower and not having to worry about something accidentally getting picked up and launched. It is really nice and quiet plus having an offset to cut the road shoulders so I would like to get this sorted out.
I used a NH 918H flail for 16 years to mow everything from residential lawns to heavy field grass and light brush. Great mower! The cut quality on residential lawns was very good, couldn't tell the difference between the flail and the Hustler Z zero turn mower. The only maintenance required was greasing regularly and sharpening the blades several times. The original belts were still good after 16 years use. The direction of rotation was whatever was set at the factory. The NH 918H has far more rows of blades than the Land Pride FM 2584 with Y blades I now own which I believe is the reason for the better cut quality on residential lawns. The 74" model I owned had 48 stations with 96 blades. If your blades are in decent condition, flip or sharpen them. Otherwise get a new set from Flailmaster. You will need to replace all the blades as a set to maintain rotor balance. Good mowing! Vic
/ Let's talk flail mowers #5,862
You use the top link to control the height, extend it a little. Then raise your skids a hole or two. Will still hit the skids before the roller. It's not an either /or, both can be kept in good shape.
I will try to adjust it as you suggested when I receive my new skids. As it is set now, when the mower is resting on flat ground the roller is 1/2 inch higher.
Now I am not sure what you mean by adjusting the height of the mower with the top link. My understanding of the top link function is for adjusting the longitudinal level of your implement, in this case the flail mower.
On my rig I adjusted the top link, so the pin is located in the center of the slot of the mower hitch frame, when the mower is resting on a flat ground (see picture).
The only way I know for adjusting ground clearance of an implement is with the hydraulic 3-point hitch. The position control lever lowest limit can be set with a lock bolt on the quadrant. I wish my tractor was equipped with a draft control, but it is not.
/ Let's talk flail mowers #5,863
How come I can't find any prices on flail parts from Flailmaster, Montage, etc? I used to have a lnk to a flailmaster catalog that listed prices, but now that link is dead. It sure would save time on the phone to know what knives are going to cost, instead of me asking "how much are the standard duty blades? Well, how much are the heavy duty? How about the extreme duty?" wasting my and the phone rep's time.
Also, I just got done cleaning up my Alamo SH88. Sanded, painted. I want to put the decals back on there. Called Alamo and they quoted me a "Decal Kit" for $180!!! Sounds a bit stiff, to me. After all, I'm basically advertising their product by putting their name back on it.
/ Let's talk flail mowers #5,864
Besides adjusting the mower differently, you could also get a fabricator to weld extra material on the faces of the new (or old) skids.
I had thought about using a fabricator to reinforce the skids, but I bet I would have paid more than just buying new ones ($74.00 for a set). However, my problem is with ASC (Agri Supply Co.) in North Carolina. They are the sole US importer for Caroni, and they do not want to bother complying with California Prop 65.
Therefore, they will not ship anything to California. This creates a problem for me (and any Caroni customers in CA) because if anything was to break on my flail mower I will not be able to find replacement parts, except by ordering them directly from Italy, if it is even possible. Shame on ASC!
/ Let's talk flail mowers #5,865
Ok, now I understand. My Dandl does not have a slot. I lower my lift arms all the way down so they float. The top link holds the top of the mower back, and the lift arms hold the bottom forward. The mower rides on the rear roller and follows the terrain in the exact relationship at all times. By extending the top link, the mower pivots up, raising the rotor higher. When I go through a divot, the arms just raise up in float. My lift arms have slots to allow the mower to follow the ground when one end needs to be higher than the other.
I know none of this helps you. I would like someone else with a caroni to chime in to see what they do. How do you maintain the same cut height with the slot? Seems like the mower would change the angle of attack over every bump. Reach out to Island tractor as he seems to have been using a 1900 caroni for years.
Sorry for the derail
Lnk
/ Let's talk flail mowers #5,866
The skids are actually reasonably priced! But welding some flat stock on there would not be that expensive either, the only difficult part is bending it to match curve of the skids. Difficult for many home mechanics, not for a pro fabricator or an experienced amateur.
I'm also concerned about ASC's new California policy since ASC was the best place to get parts for my Kodiak rotary cutter. Apparently there's a Prop 65 commission who changed some rules recently to require Prop 65 statements to specifically mention at least one chemical that's carcinogenic rather than a blanket statement (which everyone ignores). I've found a few references to businesses who have temporarily stopped selling to CA until they can upgrade their systems to track the added information, and get it from their suppliers. But there are many that are smaller than ASC who are dealing with it. ASC's response could be political. I've seen some businesses who hate California (or the image they have of California which is often based on inaccurate media) so much that they won't sell to CA residents. But I wouldn't accuse ASC of that without knowing for sure. I can't find a statement about their California policy on their web site.
Here's a couple links about prop 65:
The Impact of California Prop 65 on Ecommerce | Practical Ecommerce
Online wine yes, coffee no: Scrambling to keep up with California's new Prop. 65 toxic warnings | CALmatters
/ Let's talk flail mowers #5,867
Repairing a seppi sml 200 put 3 sets of blades/shackles on each end of rotor. not missing any other flails but I have used a couple generic blades but tried to place them equally around the rotor to keep balanced. I'm still getting rotor vibration. Do I take a magnet mounted dial micrometer on the rotor to determine if the bearings are bad?
/ Let's talk flail mowers #5,868
Hello 10backacres,
If the knife mounting stations are not within each others orbit that will be a huge problem as it will not spin up as a balanced flail mower rotor.
The safest way is to use a mechanics stethoscope to check for bearing noise with the mower operating at 540 rpm. I would remove the knives and shackles and then run it up to 540 RPM to check for vibration. If the rotor is still vibrating still I would double check each housing using a mechanics stethoscope for noise and once you found the bad bearing plan on changing both of them as the opposing bearing will fail some time in the future.
/ Let's talk flail mowers #5,869
I am not even sure if they mail a catalog out anymore. The cost of decals is something that they-Alamo will always make a lot of money on and it costs very little to have the printer make them.
If the ID tag is still riveted to the mower and in good condition I would not worry too much about it.
/ Let's talk flail mowers #5,870
Hello Leonz I'll probably remove all of the flails on the 200 that's 52 bolts! All in locations too tight for access with air tools so it's a hand wrench job. My son thought a dial indicator on the end of the shaft would work. Do you think I should intersperse the new flails along the whole rotor rather than at each end since they all have individual orbits,and use only 1 new flail with an older flail per shackle? I've always lightly touch sharpened each blade in the past, would that have changed the balance?
/ Let's talk flail mowers #5,871
A little more info, it is a 74" cut with 48 stations, 96 blades. Here are some pics I took of it right after I got it home. Any and all help is appreciated as I would really like to get this to leave a mostly smooth cut.
/ Let's talk flail mowers #5,872
I worried about that on my old 917 when I was short some flails. I was surprised at how smooth it ran when I lost a couple knives due to some rocks. It wasnt that smooth, but it was suprising it didnt sound at all like it was trying to tear itself apart. I tend to think you'll be fine doing any reasonable job replacing knives as long as you stick with the same type. Interspersing them evenly would be the best option.
/ Let's talk flail mowers #5,873
Eric, Thank you for your Prop 65 links. While I understand the original goals of Prop 65 (I may have voted for it), its application went too far. We can see that the CA trial lawyers are the winners. After reading the material, I understand why some ecommerce companies do not want to deal with it and refuse to ship to CA.
/ Let's talk flail mowers #5,874
Hello and good morning John0829,
The cutting edges are pretty dull john, I would flip the side slicer pairs and see how
well they look. you may just luck out and have a good set of edges on the opposite side.
Its nice to see that you have a trash election door on your flail mower as you can mow in deep thick brush and eject it quickly without clogging the flail mower.
Just be sure that there is no one within 300 feet of the flail mower when mowing with the trash door open.
If they are not damaged they will spin fine.
The last time I checked micromark was selling their wet well grinders for $99.00 Plus tax and shipping and the folks at master craft were selling
their gauge setting tool for $25.00 plus tax and shipping and you will have a perfect edge every time as the wet well grinder spins at a very low
rpm and the temper on the steel will not be ruined.
My father used a table belt sander in his wood shop to sharpen his side slicers(not crazy about that but it worked).
Be sure to have the swear jar handy :^0
It will be worth your while to invest in fine thread allen head bolts and use blue Loctite to secure the fine threaded nuts to replace them as needed.
Using a long handled Allen wrench will give you more leverage to loosen them if and when you need to change side slicer pairs.
I would suggest that you
1. wear good thick leather gloves
2. invest in a new pair of high quality 12 point box end wrenches as you will have an easier time in removing the nuts and bolts.
3. a big bottle of blue Loctite(don't let it freeze)
/ Let's talk flail mowers #5,875
I found this Micromark Sharpener for ~$125 plus S/H.
Which Master Craft gauge setting tool are you referring too? There are about a jillion links when I search!
/ Let's talk flail mowers #5,877
So lets get back to the way these things are adjusted to mow. I have the Caroni also so I have a hole or a slot to hook the top link to. I've tried both and not sure how much difference it makes.. AND apparently having the skids at the same height/level as the roller is not correct either and I have the grooves all over the place to prove it.
So how bout a tutorial/discussion on how AND why everyone adjusts and hooks up their flail..
thanks...
/ Let's talk flail mowers #5,878
thanks...
Lengthening the toplink forces the flail to rotate backwards which pushes the rear roller down and increases the cutting edge to ground distance.
Aaron Z
/ Let's talk flail mowers #5,879
I will flip the slicers pairs first chance I get, raining here for the next several days according the the forecasters and the shop is to full to get it inside, then will report back on how it does. I did take a side grinder and touch up the slicers though the rear door after I got it home thinking it would help. If this improves the cut I will purchase a new set to have on hand for next time it needs it.
I will check into a wet grinder, its about the only tool I do not have, I tend to do all blade sharpening on the belt sander since I discovered YEARS ago how nice an edge it put on them.
/ Let's talk flail mowers #5,880
..............The last time I checked micromark was selling their wet well grinders for $99.00 Plus tax and shipping and the folks at master craft were selling
rpm and the temper on the steel will not be ruined......................
I have the exact same wet well sharpener but with Craftsman name on it.
It's a fine sharpener for woodworking chisels, knives, maybe even occasionally axe and such but I would never even try to use it for flail mower blades or any mower blades for that matter.
It was intended for lighter duty sharpening and will do pretty good job at that.
Just my opinion based on personal experience on using one.
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2016 Chevrolet Silverado 3500 Flatbed Truck, VIN # 1GB4KYC8XGF238980 (A65563)
2016 Chevrolet...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
