Shop Walls
/ Shop Walls #61
You got through the tough part, making your decision after all our suggestions. :thumbsup: Good luck with your project and don't forget to post pics! We all like to see how things turn out.
/ Shop Walls #62
Decision Made: I'm going with plywood.
Lots of great suggestions. I really like the Puck Board idea, but not easy to source. 3/4" plywood sanded on one side and painted is the way I'm going.
It will be 1/2" off the concrete floor to avoid direct contact and minimize moisture. I will also paint the plywood front, back, and all edges to seal it.
Thanks everyone.
Doug
Are you going to do anything to seal the 1/2” gap? If you are insulating your walls, that’s a nice little entrance for rodents to make a home out of your insulation. They’ll find a way in eventually, but a gap like that all over is an open invitation to free room and board!
/ Shop Walls #63
If it is standard stud construction, the bottom plate will accommodate that
/ Shop Walls #64
Thanks everyone.
Doug
Sounds good!!!! Make sure to post pics during the process and the finished product!!! Thanks for the update!!!
/ Shop Walls #65
Yep. I just left a 1/4" gap and then filled it with caulk. I didn't want a crack for a welder or torch spark to get into.
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
2001 INTERNATIONAL 4900 (A67714)
2001 INTERNATIONAL...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2010 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2010 ALLMAND...
