Weird temperature problem JD 310SG code F450
/ Weird temperature problem JD 310SG code F450 #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
What's happening is that our JD 310SG backhoe runs fine and doesn't overheat. But during the warmup at idle after about 5 minutes the temperature gauge begins to climb rapidly to the top of the scale. That sets off alarms and throws service code F450. I'm told that code is for the temperature sensor on the thermostat and indicates zero voltage at the sensor.
None of this makes sense to me. There's plenty of good coolant, the engine runs well and doesn't seem to be overheating, but the tractor thinks it is getting too hot.
Any ideas?
rScotty
/ Weird temperature problem JD 310SG code F450 #2
sounds like the thermostat needs replaced. It's taking a higher then normal coolant temp to open it causing the F450 code and the gauge to spike.
So you believe it's the thermostat rather than the temperature sensor in the thermostat housing. Well, I suppose one way to test that would be to simply remove the thermostat.
That's not much work to do, but it would be even less work to simply test the sensor... I wonder how to do that?
Does anyone have any information on the 310SG thermostat temperature sensor? How it works?
thanks,
rScotty
/ Weird temperature problem JD 310SG code F450 #4
When you cold start the tractor and let it run for awhile does the temp gauge go up to the top of the scale then does it come back down ?
Sounds like the reason the sensor it throwing the code is because when it's hot the voltage drops causing the code F450 which I believe is the way it should work. You sure the sensor doesn't control the temp gauge also.
No, it doesn't return as long as the engine is running. When started from cold, It takes a few minutes for the temperature on the gauge to begin to rise, but once it does, it stays up there.
The more I think about it, the more I agree with your initial thought that it is simply a defective thermostat. It's the simplest explanation and would explain everything I'm seeing as well as meaning that both the sensor, temp gauge, and alarm are all doing their job just as they should. To support that, I just went out and started it (it has always been an instant starter) and saw that the temperature gauge was at full cold just as it should be after sitting all night. And the "check engine code" light was on.... again, just as it should be.
So if it is the thermostat, I think what fooled me initially was that for months now it hasn't happened by occassionally. and also the few times it did happen iI was just moving the machine around the yard so it never got so hot that it steamed or even heated the water in the radiator substantially - like what happens via the lower hose when an engine really heats up. I've just been purely lucky.
The only time I missed the alarm was for less than a minute and was because I was wearing the noise-canceling headphones. Good headphones, but one of the things they cancel real well is alarms.
I feel confident enough that I'll pick up a thermostat tomorrow at JD. Someday I'll get a workshop manual, too.
Got a few days, raining now & two days of snow forecast.
thanks,
rScotty - "its better to be lucky than smart"
