Need Help ASAP -- Hydraulic Fitting Size?
/ Need Help ASAP -- Hydraulic Fitting Size? #1
NCFarmLife
Member
Mahindra 4540
I asked this question over in the Mahindra section, but I'm not getting any response and my tractor is down until I figure this out -- so needing some help ASAP.
I'm setting up a hydraulic auger on my Mahindra 4540 Front End Loader and I have all the hoses and fittings for the new control valve, but I ran into one fitting that is different. This is the inlet hose that goes from the pump output to the input on the FEL control joystick. I think the control valve is a Besko model, but there is very little/no information out there on it and I can't figure out what fitting type/size I need.
Does anyone know what type of fitting is used on the Mahindra FEL control valve?
I do not have a good local hydraulic shop, so I have to order all this stuff online and shipping is killing me. I can't be playing the "see what works" game.
Here are a couple pictures to help...
/ Need Help ASAP -- Hydraulic Fitting Size? #2
Looks like JIC. Don't have a Mahindra so I don't know size. You should be able to find some sizing info online.
/ Need Help ASAP -- Hydraulic Fitting Size? #3
My guess would be #8 JIC which equals 3/4" SAE - NF thread. But guessing doesn't help you.
You really need some calipers and a thread gauge.
This might help.
/ Need Help ASAP -- Hydraulic Fitting Size? #4
This might help.
Same thing he was told in the Mahindra section.....time to measure.
OP- a lot of local auto parts stores, truck repair shops etc have hydraulic parts. Hopefully their are local options to help you out.
/ Need Help ASAP -- Hydraulic Fitting Size? #5
View attachment 597427View attachment 597428
This is just a general purpose field guide, does not apply to all
JIC # size/Wrench size
#4 - 9/16
#6 - 11/16
#8 - 7/8
#10 -1"
#12 - 1 1/4
#16 - 1 1/2
#20 - 2"
A picture of the other side would have helped too. Flat, flare, etc...
/ Need Help ASAP -- Hydraulic Fitting Size? #6
Are you putting the new control valve between the pump and the loader valve? Usually you add valves on the power beyond circuit off the loader valve.
/ Need Help ASAP -- Hydraulic Fitting Size? #7
"Are you putting the new control valve between the pump and the loader valve?"
I would be EXTREMELY cautious doing that - I found out the HARD way ($400 for a new pump) that some tractors incorporate the main system pressure relief in the LOADER VALVE - my first attempt at plumbing in a hydraulic sickle bar AHEAD of the loader valve ended up with the pump splitting in half when the sickle hit a really hard limb and stalled. Sickle now gets fed from its own valve AND pressure relief, AFTER the loader valve....
fitting size - if you're not sure even after checking wrench size, (as mentioned, this is not infallible) after you find a local supplier, buy just one (opposite *** from yours) adapter in the size you THINK is right, take it home and see if it screws into what's there - should cost somewhere between $1.50 and $4 to find out for sure... Steve
/ Need Help ASAP -- Hydraulic Fitting Size? #8
This could also be 30 degree flare fitting. I know that it what is on my Branson. Totally different thread size than JIC 37 degree flare
/ Need Help ASAP -- Hydraulic Fitting Size? #10
Sorry I missed your comment about no local hydraulics - maybe this will help
https://www.discounthydraulichose.com/mm5/thread_guide.pdf
Oldnslo makes a good point,( look at JIC, compared to JIS several pages later) and (for 3/4" size, anyway) the two are only about .002" different male thread diameter, so even a digital caliper wouldn't guarantee which yours is - check out both in the above guide, the bigger difference is the angle. I would hold a small straight edge against the angled part of the male, and find a way to measure that angle (see pics in the chart) - there's a noticeable difference in how steep a 30* angle is when compared to 37*.
Best I can offer, HTH... Steve
(Looks like Ericm already linked the chart :=)
hydraulic supplies are all over North Carolina!
You see that big empty space in the middle with no red dots anywhere near it - yep, that's where I live... BUT, I did call a half-a-dozen tractor dealers around here on a tip and asked where they get fittings in a pinch and I think I may have a place about 20 mins away. Going this afternoon to talk to them.
That was the initial plan, yes. The 3rd function control valve has its own pressure relief, so my understanding from my research is I would be safe doing this.
So now we have a third contender. I'm just going to buy a digital caliper while I'm out and I'll measure tonight. I've *heard* they are BSPP fittings, but according to the links provided, BSPP doesn't have a flare like that. Just amazed/frustrated these manufacturers produce *zero* documentation on their parts, the dealers know nothing and apparently I'm the first to try this? (worrisome as well)
/ Need Help ASAP -- Hydraulic Fitting Size? #13
NCFarm,
The 30 degree flare or cone is called JIS cone seat and has BSPP threads.
3/8 or -6 3/8-19 thread Male 21/32 (.656) OD Female ID 19/32 (.594)
1/2 or -08 1/2-14 thread Male OD 13/16 (.813) Female ID 3/4 (.750)
These look very similar to JIC 37 degree but like stated earlier they will not interchange.
For added confusion on my Branson they used the 30 degree cone for the hydrostatic cooler lines and power steering. Used mix of JIS 30 degree & JIC 37 degree for most of the FEL lines.
This might explain why some people are saying it's BSPP, but it looks like JIC.
OK. I measured these on the female end and I'm getting 0.691" - so that would mean its either a JIC -8 37 deg or SAE -8 45 deg, right?
/ Need Help ASAP -- Hydraulic Fitting Size? #16
Sure sounds like it; I'd bet JIC, I haven't heard of any tractors using THAT particular "SAE" fitting, but I've been wrong at least ONCE in the last 74 years :D
If you have some kind of protractor, or a sliding square, you should be able to (if accessible) hold it up to the male flare's edge and see if the 45* side is lined up with the hose - if it's exact, it's a 45 - if it's off, it's one of the other two possibles. Thread pitch on that size is 3/4-16 on both the JIC and SAE, and 3/4-14 on the JIS.
If your eyesight's good enough, you could count the threads in 1/2" (not likely that area is 1" long for that size) - if you get 7 threads in EXACTLY 1/2", it HAS to be the JIS - if you get 8, you'll need to figure out the bevel angle somehow... Steve
Actually, I forgot - if you're sure about the .691" inside, it's down to finding what angle the bevel is since they're BOTH the same thread pitch...
This is the male end... I counted 6 threads total, 0.732" OD - still trying to locate a protractor to figure out the angle. Haven't used one since grade school... also a bit concerned with that corrosion on the inside.
/ Need Help ASAP -- Hydraulic Fitting Size? #18
I wouldn't worry much about the corrosion; these only seal on the bevel part, so it's pretty easy for rainwater to get to the threads - I've cleaned dozens of JIC's up with a fine wire brush on the threads, shined up the bevel with gray scotchbrite, they never leak. If it sits out in the rain a lot, maybe dab a little never-sneeze on the threads when reassembling.
The bevel on that one looks a LOT like a 45, but I'd take that fitting with you if you're gonna get some hoses made, kind of a spendy mistake if you're wrong - also, if you can't find a protractor you could slip a round rod into the hole on the male end (as snug a fit as possible), then hold the square end of a ruler against the bevel so that the length of the ruler runs toward the far end of the inserted rod - if you can hold all that steady, then for every inch you get from the fitting, the ruler whose end is against the bevel should be an inch further from the inserted rod. It's just like roofing; a 12/12 pitch is 45 degrees.
BTW, a 37 degree angle is almost exactly 9/12 pitch - so there's a little "wiggle room" in this endeavor and STILL probably get it right... Steve
/ Need Help ASAP -- Hydraulic Fitting Size? #19
Certainly looks like JIC to me- Take a look at our thread guide:
Page 4 is JIC
IMHO, it is unlikely that you are dealing with JIS threads, but it always is a possibility, but unlikely....
If you aren't handy with calipers- you can always get a few JIC tube plugs to confirm sizes.
Let me know what I can do to help.
-Blake
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2005 Toyota Sienna Van (A61569)
2005 Toyota Sienna...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
1990 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 2J4FY29T5LJ516997 (A61165)
1990 Jeep Wrangler...
