Need Help ASAP -- Hydraulic Fitting Size?
   / Need Help ASAP -- Hydraulic Fitting Size? #1
NCFarmLife
Mahindra 4540
I asked this question over in the Mahindra section, but I'm not getting any response and my tractor is down until I figure this out -- so needing some help ASAP.
I'm setting up a hydraulic auger on my Mahindra 4540 Front End Loader and I have all the hoses and fittings for the new control valve, but I ran into one fitting that is different. This is the inlet hose that goes from the pump output to the input on the FEL control joystick. I think the control valve is a Besko model, but there is very little/no information out there on it and I can't figure out what fitting type/size I need.
Does anyone know what type of fitting is used on the Mahindra FEL control valve?
I do not have a good local hydraulic shop, so I have to order all this stuff online and shipping is killing me. I can't be playing the "see what works" game.
Here are a couple pictures to help...
   / Need Help ASAP -- Hydraulic Fitting Size? #2
Looks like JIC. Don't have a Mahindra so I don't know size. You should be able to find some sizing info online.
   / Need Help ASAP -- Hydraulic Fitting Size? #3
My guess would be #8 JIC which equals 3/4" SAE - NF thread. But guessing doesn't help you.
You really need some calipers and a thread gauge.
This might help.
   / Need Help ASAP -- Hydraulic Fitting Size? #4
This might help.
Same thing he was told in the Mahindra section.....time to measure.
OP- a lot of local auto parts stores, truck repair shops etc have hydraulic parts. Hopefully their are local options to help you out.
   / Need Help ASAP -- Hydraulic Fitting Size? #5
View attachment 597427View attachment 597428
This is just a general purpose field guide, does not apply to all
JIC # size/Wrench size
#4 - 9/16
#6 - 11/16
#8 - 7/8
#10 -1"
#12 - 1 1/4
#16 - 1 1/2
#20 - 2"
A picture of the other side would have helped too. Flat, flare, etc...
   / Need Help ASAP -- Hydraulic Fitting Size? #6
Are you putting the new control valve between the pump and the loader valve? Usually you add valves on the power beyond circuit off the loader valve.
   / Need Help ASAP -- Hydraulic Fitting Size? #7
"Are you putting the new control valve between the pump and the loader valve?"
I would be EXTREMELY cautious doing that - I found out the HARD way ($400 for a new pump) that some tractors incorporate the main system pressure relief in the LOADER VALVE - my first attempt at plumbing in a hydraulic sickle bar AHEAD of the loader valve ended up with the pump splitting in half when the sickle hit a really hard limb and stalled. Sickle now gets fed from its own valve AND pressure relief, AFTER the loader valve....
fitting size - if you're not sure even after checking wrench size, (as mentioned, this is not infallible) after you find a local supplier, buy just one (opposite sex from yours) adapter in the size you THINK is right, take it home and see if it screws into what's there - should cost somewhere between $1.50 and $4 to find out for sure... Steve
   / Need Help ASAP -- Hydraulic Fitting Size? #8
This could also be 30 degree flare fitting. I know that it what is on my Branson. Totally different thread size than JIC 37 degree flare
   / Need Help ASAP -- Hydraulic Fitting Size? #10
Sorry I missed your comment about no local hydraulics - maybe this will help
https://www.discounthydraulichose.com/mm5/thread_guide.pdf
Oldnslo makes a good point,( look at JIC, compared to JIS several pages later) and (for 3/4" size, anyway) the two are only about .002" different male thread diameter, so even a digital caliper wouldn't guarantee which yours is - check out both in the above guide, the bigger difference is the angle. I would hold a small straight edge against the angled part of the male, and find a way to measure that angle (see pics in the chart) - there's a noticeable difference in how steep a 30* angle is when compared to 37*.
Best I can offer, HTH... Steve
(Looks like Ericm already linked the chart :=)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
Athey 7-12 Force Feed Loader (A52384)
Athey 7-12 Force...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
