Septic Alarm went off
/ Septic Alarm went off
I had a similar problem. Turned out the pump was 120V and the wiring was 240V. The pumps were burning out every 6 years.
I discovered the cause after my wife ordered a different brand pump, she works in waste water engineering and was the subject matter expert. The new pump had overload protection and would stop running after a few seconds. When I looked at the pumps spec-sheet I saw it was 120V and I was sure my wife made a mistake, because I knew the wiring from the house was 240V. My wife was right, the original pump was 120V, and it was wired wrong when the house was built.
Wow, what a bad break! You should maybe post a complaint online about that installer!🤨
/ Septic Alarm went off #42
Mine only has 2 floats, and as I said earlier I will be checking them out when the snow and ice go away.
And thanks again for all the great suggestions, guys! It is nice to know you have a TBN community behind you when you need it!
Now if only I could get rid of them pesky attack beavers that keep setting up shop under my big old boathouse...
the more basic systems use 2 floats. The lower one cycles the pump, the upper one is the tank full alarm. Ill bet you its the float. Ive never seen an alarm go bad. The alarm has no brain. It uses the float to complete the cycle. Theres no mechanical way inside the control to complete the cycle. Ive wired up lots of septic control systems .. but only work on new systems... cant stand the odor of used systems... most of the newer units use 4 floats. They have redundant off and on floats to help protect system and keep it working should a float fail.
/ Septic Alarm went off #43
Wow, what a bad break! You should maybe post a complaint online about that installer!��
The home was built 19 years ago and the cause was likely a communication mix-up between the electrician wiring the new home and the excavator installing the septic system, effluent under the bridge I guess!
That is good to know. Maybe I can retrofit a dual float system for the alarm if indeed the float itself is the problem. Will keep you posted!
/ Septic Alarm went off #45
We have a little treatment system made by Multiflo. It has an alarm that would go off now and then for no reason. I fixed it by cutting the wires to the audio alarm. It got annoying and I got tired of calling the septic guy out. We pay a yearly fee to have them come out and check it every year and clean it as needed. It also reduces the cost of getting the pump replaced. I hate paying yearly fees for stuff like that but like others have pointed out, who wants to deal with that stuff. Luckily mine is much lower than the house so as long as the lines aren't plugged up, no problems in the house.
OK, OP here. I have now opened up the alarm box (which, fortunately, is inside the cottage), and tested the wires going out to the float. Joy! That circuit is open, meaning the float switch is off, as it should be. (Remember we tested the functioning of the pump earlier, by running water enough to fill it up and then listening carefully outside to hear the pump star and stop after the water ran for a while.)
So, the problem is inside the alarm box, which is of course very simple, and as far as I can tell consists of a buzzer (the dark shadow in the corner), a light (the white thing with the green terminal connectors), and two terminals/switches (one of which silences the alarm buzzer, and one of which tests the alarm buzzer). My guess is that one of these switches is defective, or MAYBE the buzzer itself.
Next step is to check and see if I can get parts for this thing.
One thing that confuses me is why there is a (hot) wire which coming from the receptacle plug and going down into the cable that goes out to the float switch. Why would we need power to go out to the float switch? Is there some sort of step-down transformer?
Just looked for that manufacturer on-line and came up empty. Any other details that might lead you to the OEM wiring diagram?
Try boshart.com. I called them and they have the 850H high level alarm, but now it seems they only send 9V DC down the line to the float switch “in order to reduce the risk of electric shock”. My (16 year-old) alarm sends 110 AC (I think!)
Will have to call them again about this, and hopefully get a wiring diagram. (Hope they are open tomorrow.)
OK, went up and did a few tests this weekend. The two switches (one for "Test" and one for "Silence" both showed the correct impedence when using the switches. And now the warning buzzer seems to work intermittently when all switches are off/open. (Actually, it kind of hums like it wants to come on but can't.)
And Boshart was not open this weekend, so I will have to call tomorrow. Seems like a lot of money for a box with 2 switches, a lite, and a buzzer! ($173)
I guess, as for your question. One would have to know what kind of motor it is. Most motors though, would show some resistance. I am not a motor expert. It's complicated! There are often start windings that are centrifugally operated by a switch which can stick.
You said your AC cord was open? So no power?
Generally, I'm thinking:
Stuck impeller, bad bearing, resulting in tripped overload device or thermal shutdown. Maybe fried motor.
Bad Start or run capacitor.
Flaky float Switch.
Stuck internal motor start switch. Probably would trip Overcurrent device.
IT, remember the alarm is a completely separate thing from the pump (which seems to be working fine). It is just a float switch in the effluent tank, and the alarm box indoors. And the float switch circuit was open, meaning the float is not high enough to close the float switch. And that is just what we want. So, this "open" confirms that the float is not high enough to be in an alarm condition, and thus is NOT the problem. See my other posts, but the problem is inside the alarm box, where the alarm is going on even though the float switch is open. There is some sort of loose connection or a short somewhere, causing power to get the the buzzer (and light) even though the float switch is in the correct, "all is good", open position.
/ Septic Alarm went off #52
Cheap alarm switch:
Simply purchase a pump float switch (the kind that uses a plastic float).
THe float contains a mercury contact switch that is capable of a fair amperage.
Rig the float to make contact at whatever level you want.
You can then add an indicator light, siren bell or whatever warning U want.
Best part is the float switch is in the $25-$35 range.
/ Septic Alarm went off #53
Draw yourself a schematic.
If the buzzer is buzzing when both switches are turned off/open, then there's a short somewhere that's providing power to the buzzer. If the short isn't one of the switches (bad switch), then it's somewhere down the line outside of the box.
Draw yourself a schematic. ;)
Cheap alarm switch:
Don’t need a float switch, Bob. The existing one is fine. The problem is with one of the switches inside the control box giving power to the buzzer when it is not supposed to.
Yup. Most likely one of the switches. One has a post that wiggles a bit, so that is the suspect.
No schematic necessary, however. It’s just two switches, a light, and a buzzer. It might not be that obvious in the photo, but I can tell where every wire goes, no problem. Here it is again.
/ Septic Alarm went off #56
View attachment 597419View attachment 597420
I saw your pictures the other day and sketched out a schematic yesterday afternoon. Either I've drawn it wrong, or it makes no sense to me, or the center pole on the back of the switches are not the center poles electrically. When it's in the silent position, there's no complete circuit to the buzzer. When it's in the alarm/reset position, both sides of the buzzer are shorted together through the lamp, and there's no complete circuit anyway, unless the test button is activated.
Hopefully, I've just drawn it incorrectly. ;)
Moss, you have drawn it correctly. The two wires going out to the left are going to the float switch, and so as long as the “silence” switch is set to “alarm” (which it is not in your diagram), the system is armed and ready to go in as soon as the float switch is activated.
The problem, of course, is that one of those internal switches in your diagram does not seem to be working properly. I did check both switches for continuity, and they are as expected. Resistance is infinite when they’re open, and less than one Ohm when they’re closed.
When I had another look at it this weekend, the buzzer would hum like it wanted to go off, but did not always work its way into a full buzzer mode. However, if I activated the test switch, the buzzer would come right on full.
I think I may be dealing with some sort of intermittent electrical short, so I’m going to find a couple more switches and see if they will do the trick.
Hey, grs - thanks! Will have to check it out.
Grs, I checked it out, and with The exchange rate and all the extra fees, it comes to $135!
But it is a possibility if the Canadian company (boshart.com) that made my original alarm does not work out.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
