check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,174
- Tractor
- 2009 Kubota BX25
I had a similar problem. Turned out the pump was 120V and the wiring was 240V. The pumps were burning out every 6 years.
I discovered the cause after my wife ordered a different brand pump, she works in waste water engineering and was the subject matter expert. The new pump had overload protection and would stop running after a few seconds. When I looked at the pumps spec-sheet I saw it was 120V and I was sure my wife made a mistake, because I knew the wiring from the house was 240V. My wife was right, the original pump was 120V, and it was wired wrong when the house was built.
Wow, what a bad break! You should maybe post a complaint online about that installer!
