What is this shaft?
/ What is this shaft? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Am I the only one who doesn't know what the transverse splined shaft is for? (The one to the left and above the normal PTO shaft in the pic)
/ What is this shaft? #2
Stowage for a 1000 rpm PTO shaft insert. Pull out the 540, stuff in the 1000 !
/ What is this shaft? #3
This. Pretty standard for tractors starting around 100HP.
/ What is this shaft? #4
some are also pull out, take off other covers, flip end for end and put in other hole and put cover/place back over the one you just took out, you dont need a stow away spot ;-)
Thanks. I should have been able to figure that out.
/ What is this shaft? #6
My JD 3020 had that. I never swapped them out but I was told that if I do it, park the front tires in a low spot, have a bucket of oil handy and don't dilly-dally around pulling one out and putting the other in because you will loose a lot of oil.
Lincoln Electric Ranger Welder (A61166)
Lincoln Electric...
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
JOHN DEERE 6700 SPRAYER TOW BAR (A62131)
JOHN DEERE 6700...
BUNDLE OF MISC SIZE PINE LUMBER (A62131)
BUNDLE OF MISC...
20 Yard Dumper (A61166)
20 Yard Dumper...
2016 Lincoln Navigator SUV (A61569)
2016 Lincoln...
