How do you mark top link length on greasy threads?
/ How do you mark top link length on greasy threads? #1
rfc143
Vermont
kubota 5240
I've know, with pretty good precision, How long the top link needs to be when attached to the snow blower, the rake, the mower etc. But, short of getting a tape measure out to measure the exposed threads, or making a bunch of gauges, Does anyone know of a way to paint or otherwise mark the threads to make this quicker/easier?
/ How do you mark top link length on greasy threads? #2
I have very little grease on my top link, just enough to keep it from rusting and corroding...keeps it cleaner that way. If you have a camera phone, just take a picture of each implement you use and refer to it when hooking it up.
/ How do you mark top link length on greasy threads? #3
clean the threads and use a paint marker . I use them all the time and have different color ones on certain implements like my hay cutter and put the color of the mark on the frame so i know the color mark to set too, sharpie works but will have to be redone periodically
Cool. I'll Try that. Thanks.
Follow up question: Is there a way to unscrew the link completely? I want to soak it in degreaser and also put one of those threaded locking nut things on it rather than the hex nut on there now.
/ How do you mark top link length on greasy threads? #5
what kind of top link do you have ??? all of mine are threaded tubes and yes you can unscrew mine
I assume mine came with the tractor. If you unscrew it far enough, it stops short of unthreading all the way. I haven't tried forcing it, but I'm guessing it's some kind of interference thread.
/ How do you mark top link length on greasy threads? #7
Probably a burr or perhaps someone used the link in the fully collapsed position and the end of the threads bottomed out on the opposing half of the turnbuckle and mushroomed the end out slightly. It doesn't take much to make life difficult with threaded connections.
/ How do you mark top link length on greasy threads? #8
I have never thought about or needed to mark mine. I spray all my exposed stuff that needs lubricant or rust prevention with dry molly lube.
You could always hacksaw a line in the threads. Then you still have to remember which line is for which implement.
/ How do you mark top link length on greasy threads? #9
I use a cheap pocket tape measure which stays on tractor, and the only implement I really care to be exact for moldboard plow. Everything else you can put on close enough, step back and look and see it the implement is sitting right.
I measure pin center to center on the top link.
Of course if your tractor will take a generic top link, you can buy them fairly cheap now and leave one set right length on each implement :)
/ How do you mark top link length on greasy threads? #10
<snip>
I'd like to get to 1 top link/implement and 1 tractor per implement :)
/ How do you mark top link length on greasy threads? #11
File a flat spot about 1/4 to 3/8 long on every 4th thread. Then you can use 3 1/4, 4 3/4 etc. for your reproducible distances.
Every tenth would work easily, too. (4.6, 3.4 etc)
Bruce
/ How do you mark top link length on greasy threads? #12
Dedicating a toplink for each implement is convenient. I used to keep 2 for my most frequently used implements (finish mower and rear blade). Now I enjoy using a hydraulic toplink so it's a non issue.
/ How do you mark top link length on greasy threads? #13
Some toplinks are designed so they can't easily be disassembled. Does yours have a bolt screwed into the side of the barrel at each end? If so, remove it, then it will come apart.
/ How do you mark top link length on greasy threads? #14
The OEM top link on my M6040 has some type of "internal stop" so that the link will not unscrew completely. I suppose it could be forced - but for no good reason that I can think of.
The quick & easy answer to the length of your top link - hydraulic top link. Takes the pain out of any adjustment & allows absolute precise adjustment.
/ How do you mark top link length on greasy threads? #15
I have Amazon adds now showing on this page...toplinks for $26!
Tractor part might be harder.....
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
3Pt Bale Carrier (A66408)
3Pt Bale Carrier...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Box of New Take Off Agco/White Planter Parts (A65640)
Box of New Take...
John Deere 925 Cultimulcher (A66408)
John Deere 925...
