How do you mark top link length on greasy threads?
   / How do you mark top link length on greasy threads? #11
File a flat spot about 1/4 to 3/8 long on every 4th thread. Then you can use 3 1/4, 4 3/4 etc. for your reproducible distances.
Every tenth would work easily, too. (4.6, 3.4 etc)
Bruce
   / How do you mark top link length on greasy threads? #12
Dedicating a toplink for each implement is convenient. I used to keep 2 for my most frequently used implements (finish mower and rear blade). Now I enjoy using a hydraulic toplink so it's a non issue.
   / How do you mark top link length on greasy threads? #13
Some toplinks are designed so they can't easily be disassembled. Does yours have a bolt screwed into the side of the barrel at each end? If so, remove it, then it will come apart.
   / How do you mark top link length on greasy threads? #14
The OEM top link on my M6040 has some type of "internal stop" so that the link will not unscrew completely. I suppose it could be forced - but for no good reason that I can think of.
The quick & easy answer to the length of your top link - hydraulic top link. Takes the pain out of any adjustment & allows absolute precise adjustment.
   / How do you mark top link length on greasy threads? #15
I'd like to get to 1 top link/implement and 1 tractor per implement :)
I have Amazon adds now showing on this page...toplinks for $26!
Tractor part might be harder.....
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Trac Vac PT Lawn Vacuum (A56469)
Trac Vac PT Lawn...
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
