Fire extinguisher
/ Fire extinguisher #21
Here is mine. Mounted on the ROPS with my own bracket. I still maintained the ease of pulling the fire extinguisher fast. It just slides on a little hook on the top, while the bottom just have a strap that allow for the fire extinguisher to slide in.
/ Fire extinguisher #22
I too had difficulty finding the best mount and ended up going with a nylon version that straps on. Has worked extremely well for me and was easy to remove from my old tractor to my new.
I would recommended that you wrap some Scotch tape or a bread tie through your safety pin so it doesn't get snagged by brush, or fall out due to vibration.
/ Fire extinguisher #23
I’m more impressed by the nylon version that straps the tractor to the wall than I am the extinguisher straps!
/ Fire extinguisher #26
Scrap pile chainsaw, chain and tool holder. 5” square tube and 2x5” rectangle tube split. Bolt with spring for clamp. Doesn’t really need a clamp. Uses factory plastic blade guard which helps moving saw from shop, truck or worksite. Note adjustable rubber foot to add support for the saw. 1/2 plate on bottom. Welded to loader upright. Can safely carry chain, saw or tools on tractor.
/ Fire extinguisher #27
That looks good! Thx for sharing.
/ Fire extinguisher #29
I have one mounted to the right side of my steering column in my cab. For those with a cab, make sure it can be reached from the ground outside of the cab.
/ Fire extinguisher #33
Just a thought on fire extinguishers in general. I worked in health care and every year the fire extinguisher company came by and did inspections. When I bought my home extinguisher I bought from the same company and I take it in every few years for inspection. The last time they did a more complete periodic maintenance that cost a nominal amount. The point is to know what your extinguisher needs and have it checked so it is ready to go when you need it.
Doug in SW IA
/ Fire extinguisher #34
Doug in SW IA
Do they shake them as part of the inspection to ensure that the dry chemical doesn't settle into hard pack at the bottom?
Or just strap a new inspection tag on them?
Cause you should shake them once a year or so.
/ Fire extinguisher #35
Our stable crew foreman has extinguishers serviced twice, then after that they are replaced. She donates the original ones to charity.
Her husband had a background with dry chemical fire extinguishers and she feels this is the best method, based on his knowledge. I can't vouch for it one way or another.
/ Fire extinguisher #36
I’ve never heard that one......especially with the metal heads.
/ Fire extinguisher #37
You guys just reminded me to buy one and install it. I just never think about it but I have to do that before it's to late..
The best reminder is only one little fire.
I have had two.
One little one, and one BIG one!
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
John Deere 8320R (A64126)
John Deere 8320R...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
John Deere 320P (A64126)
John Deere 320P...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
