BIG BUD 750 HP
/ BIG BUD 750 HP
Re: BİG BUD 750 HP
: Mavi2:: Mavi2:: Mavi2:: Mavi2:: Dance1:: Dance1:: Dance1::b?? sırıtış:
/ BIG BUD 750 HP #3
Re: BİG BUD 750 HP
Better have deep wallet to own and operate. :eek:
/ BIG BUD 750 HP #6
Re: BİG BUD 750 HP
I'm curious as to where this was taken. There aren't that many places where this can be done profitably. So, I'm guessing one of the Balkan countries specifically one bordering the Black Sea.
I don't recognize the letters, but to many umlats for Russian, it's not American, English, German, or French. It also needs very large plots of land, so that leaves the Balkans.
/ BIG BUD 750 HP #7
Re: BİG BUD 750 HP
actually, California and Florida.. Big Bud 747 - Wikipedia
/ BIG BUD 750 HP #8
Re: BİG BUD 750 HP
it's actually 1100 hp, and since hp is hp, it's more economical to use one tractor for a shorter time than multiple tractors for a longer time.. fuel makes just so much HP, and for a given amount of work, you need a given amount of fuel, a savings comes in because of reduced friction losses too, each of the multiple tractors would have their own friction losses, and inefficiencies, which add up to more fuel needed, this is why the big passenger jets went with the 2 big engine design, it saves fuel..
/ BIG BUD 750 HP #9
Re: BİG BUD 750 HP
This is True IF you can tie the power to the ground. My experience with farm tractors is that you can't effectively utilize that much power.
/ BIG BUD 750 HP #10
Re: BİG BUD 750 HP
I seriously doubt you, and most other people have used a tractor that large. it's twice as large, and many times heavier than the largest tractor built before it, and it was explained that the implement sizes were many times larger than standard. and it has huge 8 foot tall tires!.. it was only taken out of service because the company that made those tires went out of business, before that, it was used successfully by 2 farms!..
/ BIG BUD 750 HP #11
Re: BİG BUD 750 HP
One of those custom made tires probably costs more than 99% of the tractors owned by most of us in this forum!
/ BIG BUD 750 HP #12
/ BIG BUD 750 HP #13
Re: BİG BUD 750 HP
When i lived in big sandy montana, big bud tractors were made up near Havre. I used to see them working in the fields.
/ BIG BUD 750 HP #14
/ BIG BUD 750 HP #15
Re: BİG BUD 750 HP
Back then, if the thing ran, it would probably run for some time. Nowadays, that thing could be taken out of action by a bad sensor or software bug. Waiting for techs to show up with their laptops. Then, it would be better to have several smaller tractors still running.
/ BIG BUD 750 HP #17
Re: BİG BUD 750 HP
but not as cheap to operate on a large farm..
/ BIG BUD 750 HP #18
Re: BİG BUD 750 HP
This shouldn't be a shock that farm machinery has gotten bigger each year, just like all other industries.. I'm from AG where most of my family is today. But when I was working around mines in the 80's, there average haul truck was in the 200 tons range. While there, I only worked on the puny sized 100 ton ones.... Today they are in the 300 and larger in size. Should we be shocked?
/ BIG BUD 750 HP #19
Re: BİG BUD 750 HP
HERE is what they use in mining today.. This Is What A $42,5 Tire Looks Like The 59/8R63 XDR - Business Insider
/ BIG BUD 750 HP #20
Re: BİG BUD 750 HP
Largest that I have personally driven in the field is 325 HP Steiger. Neighbor has newer 530 HP Case IH (Steiger). Our chisel plow is 27 feet and his is 32 feet. We have trouble pulling ours if the conditions are less than ideal and so does our neighbor. He has frequently commented that at reasonable field speeds you can't effectively tie the power to the ground which is the same issue we have.
Both have duals, wheel weights and or banana weights.
How large of a tractor have you operated on a farm?
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2013 VOLVO ECR88 (A65643)
2013 VOLVO ECR88...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
