Rear Blade Everything Attachments Land leveler Review
/ Everything Attachments Land leveler Review #21
I have 4 ft, 6 ft is a lot of frost, the roads are pretty bad, I can't open two buildings right now, it's a pain..
We have little snow cover and colder than average temps which drives the frost deeper. I work at a surface coal mine so we have to constantly rip frost ahead of the draglines and excavators and anything else moving dirt with cat D11 and D10's.
The more snow cover there is it insulates the ground so the frost doesn't go quite as deep plus the amount of moisture in the ground makes a big difference too which changes things up from year to year.
/ Everything Attachments Land leveler Review #22
The more you drive heavy equipment over frozen ground the deeper the frost.
In November all I do is hope it doesn’t snow before the ground freezes.
/ Everything Attachments Land leveler Review #23
Smokeydog I enjoyed your success story. I too enjoy and appreciate the huge benefit that a LPGS (land plane grading scraper) can offer the road maintainer when he adds one to his arsenal of tools. :thumbsup::thumbsup:
gg
The driveway and I have almost a 50 year history together. Have learned what not to do as much as what works. We live winters in a constant freeze, thaw, rain cycle, on a hillside, facings north, thru the woods ie green tunnel. Don’t know if I fully understand all the dynamics of what the land leveler does, but see a remarkable improvement in driveway maintenance. When I used a grader blade for maintenance, 95% of the time the blade was pulled backwards to smooth and gently pull gravel back into place. The land leveler simply does this better with blades facing forward.
/ Everything Attachments Land leveler Review #26
I plan to buy one of these when I get some cash in my pocket. My steep access road has never been perfect, but a box blade smooths out the ruts after gully washers come through.
I think the land leveler looks like it will do a much better job than my little 6 foot box blade, especially if it will help me keep a crown in the road. My soil is very rocky, but keeping limestone gravel from washing out and down the hill is impossible.
/ Everything Attachments Land leveler Review #27
You won't be sorry! It will do a much better job than the box blade and sooooo much easier.
In the EA Channel Group, we have some guys who are serious about driveway maintenance because they're in the business. Jason from Ohio has provided TONS of feedback and pics of his EA land plane and I'm proud to pass it along. He has our 72" model with ripper shanks on his John Deere 3046R.
"Got my new 72 Everything Land Plane recently and couldn't be happier. I own another brand and my family has welded our own land planes in the past. Hands down without even a close second the best built land plane I have ever seen is the Everything Attachments land planes.
Couple things I looked for in a new land plane:
Tall sides to handle lots of material
Replaceable runners (yes I wear them out annually, but my use is 200-300 driveways a year averaging about 500?
Available spare blades, runners, rippers, bolts etc.
Rippers (be careful using them, see my tips below)
Thick steel/heavy duty
Weight is your friend and if built heavy duty, you get a benefit of less chatter with more weight
Extreme compound angle of blades (other use less of an angle, it' like a good steak knife sawing into a steak?
Green paint for extra hp
All welded construction, not bolted together (some companies care more about breaking them down for shipping than they do building them right, I notice a lot of 3pt setups bolt onto the land plane, junk...)
My family has 3 miles of privately owned driveway and I've been maintaining it since I was a kid. I also have a small excavating business and repair and install new gravel driveways in the central Ohio area. I have more time than I would like to admit with land plane hooked to the back of a tractor. I average about 200-300 driveways a year averaging about 500 each and we have good hard limestone in my area.
Ted and Peanut do a great job in their videos explaining how they were designed and built and how to use the land plane on your gravel lane. If anyone has any questions about how to use them, I would be glad to help, either send me a private message or ask away. This is in no way a paid endorsement, I paid full price for my Everything Attachments land plane and just wanted to help anyone on the fence about ordering one from these guys vs buying local, my advice is BUY FROM THESE GUYS. Forget wrapping it in the loan of your new tractor, I get it... low financing and all, it's not worth paying more locally and getting less quality and engineering than you can get from Everything.
Couple land plane tips for folks:
-Size it proportional to your tractor, hills eat up horsepower and the amount and size of your stone can take additional horsepower. For example I have a 1025R and use a 60 land plane it's okay for flat ground, but if you have hills you may back it down in size, also the sub compacts have weaker 3pt hitch components and wider land planes increase wear and tear, I've broke lots of stuff on my 3pt on the 1025R... I use a 72 land plane behind my 3046R and similar to the above scenario it can be bogged down in hills, but generally speaking is well within proportions. The folks at Everything are great and helping you size implements for your tractor, just bear in mind your scenario and if on the fence and you have hills, opt for the smaller land plane."
Check out what's on the rear of his tractor in this pic, which was taken when he first received it...
Before and after pics
I probably have more words of wisdom from Jason and others, so I'll try to dig(pun, yeah) some more up for you guys!
I hope you enjoyed the insight.
Travis
Nice pictures. On my 140 acre farm the only level ground is where I make it. To re-rock my driveway costs more than land leveler. The land leveler recovers existing gravel and builds a base that takes less maintenance. 330’ elevation change in 1/2 mile. Getting water off the driveway is essential. When it is steeper it requires a precision grade. I don’t get the ruts like I use to. Doesn’t require constant adjustments like a grader blade or box blade. Drop, pull and go. My skids were showing considerable more wear on front so adjusted top link longer. Skids are replaceable but not of abrasion resistant steel??? Might have to reverse, replace or add hard surfacing rod.
/ Everything Attachments Land leveler Review #29
Travis
some of those "after" pics HAD to of had new gravel put down, right? a land leveler works that good?
/ Everything Attachments Land leveler Review #30
I am looking forward to before and after pics of the couple roads I am going to tackle in the spring, one has severe wash boards that nobody has been able to cut out and the other was a road i rebuilt with a box scraper, it was washed out and dished in the middle, i filled the washouts and got crown back into it but with the box scraper it developed several moguls that got worse with every pass and no matter what i did with the box scraper they just got worse and worse so i quit before the dirt bike gang wanted to set up a course lol. wanting to get those cut back down to level and hoping the land leveler works for that.
Every post has lots of pics that are perfectly level roads to start with and just freshly fluffed gravel, I want actual real road repair on hard packed gravel roads with humps and or video showing how well washboards are cut out not just a face lift pics.
/ Everything Attachments Land leveler Review #31
eubie5 : Not necessarily . Several of those before and after pictures are exactly like what my driveway would look like before and after , running my homebuilt land plane , several passes up and down it . We use a blue , crushed 3/4" shale , from a pit just down the road . Driveway is 800+ feet long . First 50 - 60 % is flat , with just a couple of feet elevation change . Last 40+ % starts out mild then increases to a 14% grade at top . My home built is 7' wide , by app. 8'+ long .
Really the only issue We have with Our drive , is every 4 to 6 years , We have usually 2 loads brought in to " Cap " the driveway , more to keep the dust down than anything . This past summer , Driver did good . But 5 years ago , the contract driver had No set chains on his tail gate , Thus when he was spreading and hit the steepest part of the grade , Poof . Instead of a maybe 2" cap , I had 6" to 8" thick blob for 75 to 100' . Been working the last 4 years dragging that excess either down the hill or up depending on were I wanted it . To move rock , I drop my front blade down 1" below the bottom of the side skids . To just " Touch up " the driveway , I have both the front and back blades set right at skid level . When in touch up mode , Our driveway will start out like the pictures with the grass growing down the middle . After 2 passes up and down , it will look like the after pictures .
Fred H.
/ Everything Attachments Land leveler Review #32
Agree with OP
Been taking care of about 2 miles of dirt/gravel road in woods for 30 years. Borrowed a neighbors land plane one day and ordered my own the next day. Been using it very happily for about 10 years. This thing is idiot proof. Just drop and go. You will soon be able to figure out best top link length and just usually leave it there. Mine is a 6" land pride. Many look the same so are probably pretty similar. Only issue is my skids wear out quickly and are expensive to replace. I hit the wear areas with Hard Face weld (suggested by my welding buddy) and have not needed to replace since.
I see everything attachments has a 10 degree edge on cutters instead of 5 degree. I do not know exactly whet effect that would have but would like to try.
/ Everything Attachments Land leveler Review #33
Why do towns with gravel roads run a grader over them yearly? It seems to smooth out the pot holes.
It's faster than any other method. And they have to do it yearly because it isn't the best method.....just the fastest.
2021 KMC 7406 (A64126)
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
