Skidding winch
/ Skidding winch #141
95+% of the time when I'm harvesting sawlogs or firewood, I probably use less than 150'. When clearing for a new trail, I'll use everything I have, and occasionally ad a length of chain to that. Often the trail is too rough or has too much side slope to take my tractor on until we get a dozer or excavator in to pull the stumps and put the final grade on the trail.
Unless I have a nice straight pull with good visibility (a rarity in the woods around here), it's very tough to use the full length without an extra person to act as a spotter. Maybe if I had a remote control winch, I could do it alone, but I prefer to have someone within sight of the tractor as well.
"95+% of the time when I'm harvesting sawlogs or firewood,"<< I probably use less than 75', I always try to back up as close I can especially to saw logs. Only place I'd need 200'+ of cable is if was doing mountain logging and yes with that much cable out an extra person for a spotter would be a must for me, other wise my 200' cable would end up in half in no time.
/ Skidding winch #142
Our existing trails do not allow us to get within 75' of the majority of our trees, and we're not interested in building a trail up to each area. However, I do agree that it makes sense to get as close as you can while still allowing a good area for bunching logs.
/ Skidding winch #144
Hydraulic winches are about like watching paint dry! Can you imagine how long it would have taken to winch that log 100 feet or even further?
Nice job on the build, but it's WAAAAY too slow!
SR
/ Skidding winch #145
Hello
I made a hydraulic skidding winch.
Here's a little video.
Maybe someone is looking to build ideas. :)
TYM 433 : Kole kärakas. - YouTube
That is a cool build! and that's a pretty good-sized log you are pulling with it. Your tractor sounds as though it's running not much above idle in that video
Are your hydraulics driven off the tractor hydraulics, or a PTO pump?
/ Skidding winch #146
Hello
You did a good job on that. At first glance I thought that it was factory made and was waiting to see what you had made.
I also like the "critter" tracks running across the top of that first log.
/ Skidding winch #148
Yes, of course, it's slower than the PTO winch. Fortunately, I don't have mountains here.
I can usually drive straight to the tree. Winch is just in case. :)
I use the tractor hydraulics and the tractor was idling.
Here are some more pictures.
DSC_0444.JPGDSC_0496.JPGDSC_0475.JPGDSC_0445.JPGDSC_0437.JPGDSC_0493.JPGDSC_0446.JPGDSC_0439.JPGDSC_0494.JPGDSC_0474.JPG
/ Skidding winch #149
SR
I just watched it, a big 10-4 on that....................
/ Skidding winch #150
This is how fast a winch is suppose to go, also this was a staged demonstration with over acting but with real actors, I could've just backed up to the tree, darn I spoiled the ending.............
L34 and PTO winch - YouTube
/ Skidding winch #151
For people who like to back up to the trees, this would be a handy rig. It would be even nicer if Virx1 integrated his hydraulic winch into the system.
/ Skidding winch #153
I debated a 3Pt grapple, but needed the reach of a logging winch, so that's what I bought. I eventually ended up buying a forestry grapple for the front end.
/ Skidding winch #154
That's typical of most logging winches. Mine is rated for 3 feet per second (180 FPM or about 2MPH or 3 KPH) with the spool half full. I'm assuming this is at the rated 540 PTO speed. I never run full PTO speed. I'm typically around 2/3 of that, but since I have 230 feet of cable and most of my pulls are probably half of that or less (unless I'm in an unusual situation), I'm also generally running with the spool more than half full, which speeds things up a bit. I'm guessing a typical winching speed for me is probably around 125 FPM.
That said, Virx1 said he's able to drive right up to most trees, so a short pull at slower speeds is probably not that big a deal for him. If he wanted higher speeds, he could crank up the RPMs to get more flow out of his tractor's hydraulics to get a bit more, or switch to a PTO hydraulic pump, if his winch could handle the flow rate. It sounds as though it works well for him, and at a reasonable cost, since he made it himself.
/ Skidding winch #155
I also made a log grapple, and for me this kit is initially enough.
With them I get my firewood from the forest :).
Grapple Making:
DSC_0927.JPGIMG_20181118_143033.jpgIMG_20181028_153100.jpgIMG_20181028_153044.jpgIMG_20181023_204346.jpgIMG_20181023_204219.jpgIMG_20181023_185746.jpgIMG_20181023_185736.jpgDSC_0938.JPGIMG_20181118_143141.jpg
IMG_20181202_133852.jpgIMG_20181202_132639.jpgIMG_20181202_132231.jpgIMG_20181202_132018.jpgIMG_20181202_133913.jpg
/ Skidding winch #156
My winch speed is rpm related, (one small tree= idle) (medium pull= 1500-2000 rpm<<<Most often used) (risk cable break pull= 2500 rpm<<<Very rarely used) extremely upset, throwing chainsaws, hammers, axes and anything I can get my hands on = blow motor wide open<<<haven't been there yet and that's probably because I dont have a Hoyt Clagwell tractor..................
/ Skidding winch #157
I may have missed something in previous posts but nowhere did i read about a simple way of starting a log with less force. If you put a choker around the log with a wrap, when you tug on it, it will give the log some inertia help by it starting with a role and then the pull in the direction you wish to proceed. You have the set the hook or choker bell on the opposite side down a the bottom
/ Skidding winch #158
That's a good point, and a trick I use often to roll the tree from behind the stump.
What is that tuck in your signature? There isn't enough of it showing to tel, but it looks like something older which you restored.
/ Skidding winch #159
Good point.
I've never put a full wrap, but often bring the hook under the log and hitch it to the choker chain that comes over the top of the log on the "back side" of the log. This does 2 things:
1) Gives the log a 1/2 roll when cable is tensioned. As you mention, it's good if log needs to get away from stump, or rock etc..., but more importantly:
2) I use a open grab link on my chokers, so this way gravity holds the grab hook on the chain, and the tension on the cable end of the choker, from the weigh of the slack cable off the top, holds it tight too.
Yes, snap hooks (which get bent to h*ll) or a proper log chain choker hook would prevent this, but it took me a long time to figure out best way to prevent the hook from falling off choker when the cable is rattling around when you're taking up the slack.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
