MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,283
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Yes, current as in time. :laughing:
One thing I was thinking about. Since the PT425 is all hydraulic, and the gas motor only turns one-way, all you'd need is an electric drive motor and an on-off switch. No reversing circuit would be needed and no speed control would be needed. You could put in speed control for the electric motor, but would it really help anything? You need full flow to create enough pressure to do the steering/FEL functions well. The AUX PTO wouldn't need full pressure, but since it's fed from the same valve bank as the FEL, which is fed from the power beyond on the steering valve, it's gonna get the same pressure anyway.
I suppose you could put in some sort of sensors to only apply the motor when the forward are reverse pedals are pushed, but I think response would be awful. And then you'd have to figure out circuitry to do the same for the FEL and steering. That's why I'd think you always want the electric motor on at speed all the time.
Just some thoughts.
Just some thoughts.
