What year did tractors get "complicated"?
   / What year did tractors get "complicated"? #11
Funny thing, back in 1988 I heard all sorts of complaints because there was no carburetor or points to adjust, so how is the average guy supposed to keep a vehicle running past 50,000 miles?
1939 was when they got complicated. They had all of those fancy pistons, valves, and carburetors which you had to adjust and replace when they went bad; clutches that you had to adjust, and change now and then if you abused them enough. Before then you just had to feed a little hay once in a while,and when they got old you could shoot them and eat them.
   / What year did tractors get "complicated"? #12
   / What year did tractors get "complicated"? #13
80's to early 90's. I don't even buy cars newer than '93. :) I'm stuck in time, as these are the last years of things fixable by a DIY mechanic.
The early 70's was a nice time period for working on vehicles as it was before emissions. Then came the emission carbs, buried EGR's under miles of vacuum hoses, and those troublesome catalytic converters.
We have come a long way and our vehicles are way more dependable now.
   / What year did tractors get "complicated"? #14
Usually I’m not a fan of needless complication but tractors have come a long way since back then. I’d buy the tractor you like and move on. It’s a good thing the old stuff is easy to work on because you sure get to do a lot of of. I have a 2011 “complicated” backhoe and my grandpa has a 1980s “simple” backhoe. I have a turn key machine and he has a turn wrenches machine.
   / What year did tractors get "complicated"? #15
One option Deere has is RTP (return to position) control of its loader. You can 4 positions in the computer.
   / What year did tractors get "complicated"? #17
HawkinsHollow, you mentioned you like Branson tractors, well, that puts you already on the right track.
You don't get any simpler new tractor than a Branson. It has little to no electronics at all. Only a few switches, relays and fuses but that's easy to fix. The only computer it gets it's the DPF data logger but since it's a mechanical injected engine, it doesn't care if it runs with or without the data logger and DPF can. Some people just replace it with a muffler and let the engine run happier, this allows them to run the tractor at the RPM they want and not running wide open just to keep the DPF happy and wasting a lot more fuel.
Other than that, it's pretty much like an old tractor as in, easy to fix and are heavy duty. While also having all the new features new tractors have. Independent PTO, telescopic stabilizers, power steering, etc..
   / What year did tractors get "complicated"? #18
Re: What year did tractors get "complicated"?
That has to be a typo. Tractor looks too good. I'm thinking 891 hours.
The picture of the hour meter on the tractor shows 8890.4 hours.
   / What year did tractors get "complicated"? #19
As to, "What year did tractors get complicated?" It wasn't a specific year, it was different years for different mechanical systems. You can sort of span a period though. I think it would be fair to say that in the early to mid 1990s most tractors were still as simple as they had been for decades. And by 2005 or a few years after, most of the new ones on the market had become more complicated.
A big reason why you can't go by date is that that tractor age isn't figured like automobiles or people. Tractor models tend to be made in a factory production run and then warehoused until they are sold - sometimes many years later. It is considered that a tractor is "born" brand new the year when they are sold by the dealer for the first time. Lots of commercial machines are made that way. Warranty starts when it is sold. That means if a typical model run for a certain model tractor is ten years, that the machine sold as a 1995 and the tractor sold as a 2005 could conceivably been built the same day back in the 90s. It depends on where they were warehoused.
Anyway, complexity depends on the sytem. For electrics, it got complicated when the old alternator, voltage regulator and battery system with it's analogue gauges began to be replaced with digital circuits and digital readouts as gauges. It wasn't long after that when engine computers became involved with fuel injection timing and emissions.
For simplicity in electrics, look for a tractor with generator or alternator, voltage regulator, battery, and analogue gauges. And no computer.
Simple diesel engines are mechanically injected. The fuel injection pump has a group of tubes leading from it to each injector. Inside the pump is a multilobe cam that is timed by it's mechanically locked position on a shaft so that it will deliver fuel to whichever injector's time it is to fire. Diesels were made that way for a long time. The simple ones still are.
None of the simple engines have any pollution or emission controls beyond a simple EGR valve. Yes, the simple diesels do smoke.
Simple transmissions use gears to transmit the power from engine to wheels. Complicated power transmissions are hydraulic...called hydrostatic, or HST.
BTW, power shift transmissions are generally considered to be in the simple transmission group.
Steering - there have been fewif any changes in power steering technology in the last 30 years. If you have a FEL, you want power steering. Same can be said of 4wd....although keep in mind that the older 2wd tractors tend to be heavier and all have a mechanically locking rear axle .... which means that they can do 90% of the work of a 4wd and can be gotten for much less dollars.
And of course 2wd means they are way less complex.
Wheels and axles. Here is where complexity is reversed. The older tractors tended to have more ways to change the width of the wheelbase than the newer ones do. But this is something that varies more with the brand than with the era. If your land is hilly, you want a tractor's wheels to be as wide as possible. Hillsides are any tractor's downfall. Tire width and a low center of gravity is something that most newbies don't even think about, but it just might be the most important single thing about their new machine.
If I was buying new today, I'd be looking only at 4WD, and mostly at HST. Computer-controlled engines are a fact of life.But if I was buying used and needed to save money while still being able to get the work done I fure wouldn't overlook an otherwise good machine just because it was an older 2wd with a gear shift transmission and hoperully it would have a a FEL and Power steering. And if I was really strapped for cash, a lot of work can still be done with 2WD, gas engine, gear shift, and a good 3pt hitch with a 3pt back bucket. But now we have gone past simplicity vs complexity and have arrived back to tractors from the 1970s to the mid-90s that will probably require some mechanical attention.
Enjoy,
rScotty
   / What year did tractors get "complicated"? #20
For a 2013 tractor, that’s an average of 4hrs of use per day, every day, for the past six years.
That’s a lot of use, and commendable for Kubota given the tractors good overall appearance.
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
(APPROX. 20) 4' X...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2014 International Maxxforce DT (A53317)
2014 International...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
