Another "Help me pick a tractor" thread
/ Another "Help me pick a tractor" thread #21
IMO I wouldn't be super comfortable running an L3901 for 1000lb round bales out on the loader. It's only ~700lbs heavier than our Ford 1500 And that one could get dicey with the 500ish bales that was even with a 800lb flail mower off the back.
I'd be looking at an MX4800 if your cost conscious or L4760 or larger if you want some bells and whistles.
When I was pricing out the MX line they were a ton of tractor for the money.
/ Another "Help me pick a tractor" thread #22
An L3901 isn’t much different than my L3800 and you’ll definitely have a hard time with 1000 pound bails if you can do it at all which I doubt. My L3240 would have done it.
/ Another "Help me pick a tractor" thread #23
Also if you're dealing with rounds on a regular basis and don't already have something like a bale barn[1]. I can't recommend them enough. With a pair of forks on the loader we can haul it out, drop it, unwrap it, pickup the hut and drop it on-top in less than 5-10 minutes. For our 500lb bales we get basically zero waste and it's a complete game changer.
[1] Bale Barns - HOME
/ Another "Help me pick a tractor" thread #24
Running them on spear on the rear is okay, I do not plan on stacking them at this time. Locals told me rounds are around 1000lbs most of the time.
Review Post #13.
/ Another "Help me pick a tractor" thread #25
FWIW, I've got 20 acres and maybe a little more hilly and around 13 acres that need bush hogging. Part time and weekends I get the bush hogging done in about two weeks with a 60 inch bush hog. If I ran all day, I'd probably get it done in a day and a half. Calculations don't take into account real life greasing, water, fuel, meal breaks plus not having square, flat fields to cut. Just trying to give you an idea of time involved.
I'm very happy with my Branson 3725H and don't think it would have too much trouble with your chore list.
BTW, I've never hayed before so may very likely be missing something here but I found a place that sells haying equipment for my size tractor. I think I could buy the equipment i needed for around $20k plus the tractor. That doesn't include ferilizer, soil prep, etc. My conclusion was that you can't justify cutting hay on @15, uneven, not flat, broken up fields.
Good luck. There are lots of great machines out there.
/ Another "Help me pick a tractor" thread #26
In using round bales of hay. They are cheaper by the pound to feed. If you every plan on feeding rounds, you will want to store in stacked. It is so much better stored inside, due to waste. I purchase about 90 rolls a year. All top quality horse hay. I have an LS XR4150 with loader, hay spear. You will want a FEL no mater what else you get. It is just something you will use all of the time. 4WD is needed a lot of the time in wet weather. Horses in paddocks in wet weather tend to make paddocks really wet. Your will need 4WD. When loading the FEL, weight is taken off of the rear tires and without 4WD you may not move very well.
I moved hay around with my old 35hp tractor, 2WD, no FEL, for many years. I made it work. But a lot of hay got wet and wasted. But it did work. I would never try to grow my own hay. I have enough land, but not the equipment or the time. Around here, most people will not do hay on the half any more. Just not worth it for a small field.(cost of moving equipment)
Take your time, talk an listen a lot. Find a dealer that you can work with. Equipment is long term. Good Luck!
We've looked into those actually. I planned on making a run in shelter for the horses and having it so I can flip the round inside of an elevated platform inside the shelter. Somewhat of a bale barn already as part of the run in.
Thanks! I've pretty much determined that a FEL and 4wd are required, almost have myself convinced I need a cab due to weather conditions in East Texas and the bees/bugs/dust situation.
You would need to find someone to process your hay on share.
Hay processing equipment is very expensive and not suitable for part-time agriculturists.
Minimal acreage for a haymaker to visit repeatedly with implement changes in order to cut, dry and bale hay.
Anyone willing to process hay on 8-10 acres will want to work really fast. Your fields need to be LEVEL. Where I live in Florida hay fields are rolled and rolled until LEVEL. Cost to have fields leveled as a service is $170 per acre.
Agreed after further research and discussions. I'll just try to make the pastures the most nutrient dense I can and then buy hay to supplement with the grain we already feed.
Alright we've been in the property about 45 days now and I am starting to get a handle on what I need around here.
I bought a garden tractor for the lawn and light duty stuff, Cub Cadet XT1 GT - 50".
It does a good job in pulling my 12cu poly cart and a 4' harrow/drag but that is about it, oh and it mowes well. I did try to do some pasture knock down and it is entirely to rough to do without beating this garden tractor into the ground. It would work in a pinch, but far from ideal.
First major project I tried to start tractorless was grading around my house. I started it by hand, that was a waste of time.
So last weekend I also borrowed my neighbor's 5100E.
Very nice tractor and it allowed me to make quick work of some immediate needs with the loader, mostly leveling the high soil around the house.
It was my first time driving a tractor, pretty happy with how it turned out all things considered. Now to put in some rock, edging, finish burying the downspouts, put in the garden, etc....
Looking forward and when I look at the property on the needs vs. wants.
Needs:
Brush hog capabilities for the acreage/pasture lands.
Loader capabilities to smooth out some land
Ability to stack rounds (This is inside of 5 years but I'd rather buy once).
Wants:
Backhoe for excavation/trenching in the woods. I'd like to extend my pond and dig it deeper, maybe stock some catfish in there and make a food plot next to it for deer. That requires power and well the $7k would cover a lot of rental for that one project...maybe best to just rent one when I need it.
I've been talking to the nearest Branson dealer, Big Red's, and am looking at the 3725C, 4520C, and the 4225C. I have no need for the hydrostat and after hopping in that big deere I've realized I don't need it. Also the 100hp the green machine had is nice, but way overkill for what I need, I never got that tractor out of B range and over 1800rpm for any of the work I did with the loader.
I do have a Massey and Kubota dealer near me, just hard for me to get over the cost factor of these new machines. After working in a cab tractor I think that is a requirement now.
I've thought about getting a UTV and putting a brush mower on it...but fear that is the wrong job for the tasks at hand.
Just thinking out loud here.
Does it make sense to finance implements with the purchase of the tractor, or pay cash if possible?
Does it make sense to roll in the backhoe with the tractor purchase or wait and buy that later as an ad on or just rent as I need it?
I do appreciate all the advise, here is a shot I took of the Cub Cadet the first day I got it and some grading shots inside the Deere.
/ Another "Help me pick a tractor" thread #31
Does it make sense to roll in the backhoe with the tractor purchase or wait and buy that later as an ad on?
If you're going to buy new and know you want the BH, you really want the BH from the start. They're much more expensive to add on afterwards and more difficult to find one matched to the tractor and get installed properly.
Implements is another one of those personal choices. Adding them into the contract means you're only paying a few dollars a month for each instead of hundreds or thousands up front. It's all about how much liquid capital you want to commit.
/ Another "Help me pick a tractor" thread #32
Like Diggin it said, ussually a lot cheaper to get everything as a package at the time of purchase. Especially expensive stuff like a BH. Try to line up your priorities and get the implementation/ attachments that you will need to do those jobs.
Everyone has different tasks and different priorities, for instance, for me a BH was far more important than a mower or box blade. I ended up finding a 72" finish mower and a box blade from an estate sale...both were brand new, puchased by the previous owner a few years earlier, but he never used them. I got them both for around $1,000. All depends on your needs.
Nice shopping!
I am really torn on this decision and with the pasture probably have a month to decide. I do have some additional liquidity coming to me this season so I could probably buy a cash utility tractor (open cab) to work with for now with a FEL, most around here appear to be 2wd. Just trying to decide if I want a cash "now" tractor that I could trade in later, or the tractor for the next 5+ years now. Always a problem with me, perfect vs. continuous improvement.
/ Another "Help me pick a tractor" thread #34
Shopping for used can be very area dependent. Before I moved out west here from the NE, I sold my Ford 1710 w/ fel and 5' bush hog for $2250. I was thinking I would just buy a similar tractor here once we settled in. Wrong! I probably would have gotten 3x as much for my tractor! There were nothing but POS for $$6-7 K and higher. Very limited to what was even available, so prices are higher and they still are! The local K, JD, and NH dealers know they have a captive market and have prices 15-20% higher than out of state dealers. I drove 1100 miles RT, to a Colorado dealer, but saved just over $5,000!.
I got REAL lucky finding the mower and box blade. The guy selling them used to restore 8 and 9N's, he happened to pick it up and just wanted to turn a quick buck.
Over the years, I've gotten tired of buying 'used' and getting burned. Many people have the opposite experience and it works out for them. The greater amount of 'selection' you have, the easier it would be to get something good. I was just reading a post in the buying/ pricing thread where a guy bought a used Branson from a dealer....it looked good...but the tranny is leaking white milky oil...he got lucky, the dealer is taking it back and refunding him. I wouldn't be so lucky!
Well I called the "big 3" around here.
John Deere. Recommended a 5055E package (with H240 loader and bale spear). $42,500, they are offering 0% @ 84 months promo financing.
Kubota recommended a M6060. He wants $42,500 as well. 0% @ 60 months.
Massey said I should go with a 1750M. $35,000, no special financing.
Branson: 4225C - $29,795
Branson 4225CMassey Ferguson 1750MKubota M6060John Deere 5055E
Quoted Price$29,795$35,000$42,500$42,500
Monthly Pay Est$448.23$579.89$708.33$505.95
Tractor Weight4,221 lbs4,299 lbs5,358 lbs7,054 lbs
LoaderBL200DL135LA1154H240
Load Lift Capacity @ Pins2,701 lbs1,760 lbs2,928 lbs2,606 lbs
3 Point LiftCat 1 - 3,637lbs @ 24"Cat 1 - 2,535lbs @ 24"Cat 2 - 3,307lbs @ 24" cat 2 - 3,192lbs @ 24"
Horsepower/PTO HP42/3648.8/38.163.5/5659/41
Now not 100% apples to apples as the Branson recommendation is quite a bit cheaper and Kubota went straight to a big gun. Deere financing is very attractive.
/ Another "Help me pick a tractor" thread #36
Out of those choices, get the Kubota M6060.
/ Another "Help me pick a tractor" thread #37
Man Kubota dealer really did go for the big one. I would think a L4060 would be where I'd start. Keep in mind that Kubota rates their loaders very conservatively. L4760 gets you up to the LA1055 which is totally sufficient for rounds. Moving dirt is all about weight, Grand L or MX has that pretty well covered.
If cab isn't a hard requirement you can find a MX4800 up here for under $30k or so last I looked. I opted for the L to get HST+ but the MX is a heck of a deal if they work out.
/ Another "Help me pick a tractor" thread #38
I would never buy a 5055E or 5065E. Listening to this video soured me on them. I believe there's more videos out there like it.
Also the engine to PTO efficiency on the Massey, and especially on the JD seems wonky.
Branson-85.7% efficient
Massey-78% efficient
Kubota-88.2% efficient
John Deere-69.5% efficient
Where did you source your numbers? The JD numbers do not match TractorData. They show 55/45. Which is a much more reasonable 81.8% efficiency.
Kubota doesn't really have an economy setup with a cab. That's why they went to the M6060. Against the Grand L line pricing is close enough, even against the L4760, to make it a no brainer to grab the M for doing the kind of work you've outlined.
A few other notes. Both the Branson and Massey are dry clutch designs, the Kubota wet clutch. Couldn't find the info for the JD.
Branson, Massey, and Kubota are all full shuttle shift. JD is a weird hybrid shuttle with 9 forward and 3 reverse.
JD engine is a 3 banger. All others are 4s.
Branson isn't turbo charged.
Kubota has the largest displacement.
JD engine is almost "square"(4.19" bore/4.33" stroke). Kubota is 1" of bore under stroke(3.7" bore/4.7" stroke). The larger the stroke is in comparison to the bore, the higher torque values produced at a given HP. Square is when the two measurements are the same. Branson and Massey fall in the middle.
/ Another "Help me pick a tractor" thread #39
To really compare the tractor brands and prices, you need to get prices for the same size tractor, with the same features from each company. Pick a PTO HP size that you think you need and get a quote from each dealer and tell them how you want it equipped. Right now the Branson looks way, way cheaper and the Massey quite a bit cheaper, BUT, they are 2-3 sizes smaller tractors. I think if you tell the dealers what specs you want and compare apples to apples, you will find much less difference in price. Dealers can easily make their tractor much cheaper by quoting a little smaller tractor with a little less features and if you don’t compare carefully, you don’t realize that. Make sure you try each tractor out before you buy. You may find out that there are some that you hate the control layout or how they operate and how comfortable you feel on them. You don’t want to end up with a tractor that you don’t like, or are scared to operate.
/ Another "Help me pick a tractor" thread #40
To really compare the tractor brands and prices, you need to get prices for the same size tractor, with the same features from each company. Pick a PTO HP size that you think you need and get a quote from each dealer and tell them how you want it equipped. Right now the Branson looks way, way cheaper and the Massey quite a bit cheaper, BUT, they are 2-3 sizes smaller tractors. I think if you tell the dealers what specs you want and compare apples to apples, you will find much less difference in price. Dealers can easily make their tractor much cheaper by quoting a little smaller tractor with a little less features and if you don稚 compare carefully, you don稚 realize that. Make sure you try each tractor out before you buy. You may find out that there are some that you hate the control layout or how they operate and how comfortable you feel on them. You don稚 want to end up with a tractor that you don稚 like, or are scared to operate.
Agree 100%.
The listed models are not in the same class/size.
The New Holland Website has a good comparison tool.
Weight/Lift Capacity/PTO HP/Price are good starting points.
But also there are tractors that are the best on paper but on real world application they are not quite there, and the opposite could be true too. Tractors that are listing xyz but when you need them to perform they deliver beyond expectations.
It is very important that you try the machine, or at least something similar, before you buy.
Good luck!
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
17601CFL (A59228)
17601CFL (A59228)
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63118)
2017 Cadillac...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
