Hydraulic Top Link M9540
/ Hydraulic Top Link M9540 #61
Do agree and could be a very big factor
Maybe it comes down to a hydraulic top link should only be used on tractors under 60HP. The MX5200 3 pt lift is 2310lb, and things bouncing around can well exceed this limit and then add in that on the TL and the check valve pressure limit could be reached momentarily.
So I'll add my little cylinder and play around with light things, and if I get a heavy attachment someday, I'll change to a screw type.
Got the eye cut off and longer one welded on yesterday
This has made my day, I can't stop laughing.
:rotfl: Try telling that to these guys that are running a 660HP articulated tractor that have a cat 4 hitch that lifts over 20,000lbs.
By the way, they use a 4" dia cylinder with a 2" dia rod.
Big and small, I build them all. ;)
That was tongue n cheek
Glad to help with the laugh.
Its all good, and just part of posting thoughts on a forum, hope it stays good hearted
/ Hydraulic Top Link M9540 #63
All I know is that it put a smile on my face and that is a good thing. ;)
/ Hydraulic Top Link M9540 #64
Well, like I said, if you never have the need for heavy implements.....you will be just fine with an undersized cylinder.
But let me reiterate I case it was overlooked...you have NO PRESSURE RELIEF protecting anything unless you are ACTIVELY moving the toplink
Installed it today and go figure another issue showed up, its a CAT 3 fitting. Guess I'll be using a 1-2 and 2-3 bushing on top.
So it goes, always something
/ Hydraulic Top Link M9540 #66
Thats odd. Why would they build Cat III on a cylinder that small?
Have no idea, I was standing there with them and said I want a Cat 2 extension. Next think I know they have 3 different weldable ends out and deciding which ones to use. One guy grabs a pin and says that's to small and they grab another. I'm sort of watching but not close. I tell them I'll be back in a few hours having to go get 15 gal of UDT. Come back and take it home, next day, WT He double hockey sticks
/ Hydraulic Top Link M9540 #68
AllDodge,
Did you have to take the cylinder apart to weld the end on or just extend the cylinder all the way? I think I am going to have to weld ends on to make my tilt cylinder and was wondering about all the heat and the seal.
/ Hydraulic Top Link M9540 #69
Just extend the ram.
Yes, just extend the ram. Use air and push it out
/ Hydraulic Top Link M9540 #71
What did you folks end up using for an m9540 hydraulic top link? I've got an m5-111 I want a hydraulic top link for looks like it's a cat 1 at the tractor pin and cat 2 at the implement. I'm guessing I will want to find a 3-in cylinder in the 24 to 36 movement range
/ Hydraulic Top Link M9540 #72
I took the easy route. Called Brian at Fit Rite and bought from him. This was in 2013. Received in three weeks or so.
Mine has a 3.5" cylinder with a 1.6" rod. No leaks or drips - never "leaks down" - been a really great addition for the eight years I've had it.
Instant gratification is great as long as you are satisfied with the quality received.
/ Hydraulic Top Link M9540 #73
Really the only thing about it that is cat 1 is the tractor end pin size. It takes a full cat 2 sized ball swivel, larger dia ball swivel and 2" wide.
I typically provide a 23 1/4"- 35 1/4" working length similar to the left unit pictured.
My current lead times are almost 29 weeks.
Agristore has some units that are in stock, you just need to decide which one would work best for you.
Don't forget to get a reducer bushing for the tractor end.
/ Hydraulic Top Link M9540 #74
I found a unit made in turkey. Shipped from apeldoorn, NL
Cat 2, 3" cylinder 1.38" rod
22.5"-33.5"
Locking block and includes all hardware
/ Hydraulic Top Link M9540 #75
