Building FEL hay spear, have a question
/ Building FEL hay spear, have a question
After m5farms mentioned the global QA I got to wondering what kubota did for a quick hitch,
it looks like they had several different so called quick attaches;
Optional “Bolt-On” Brackets
Work savers may have your QA for your kubota.
good luck
Thanks for the link, one is real close but not quite.
/ Building FEL hay spear, have a question #22
Hi Lou, I am building a spear that will attach to my loader in place of the bucket if that makes more sense. Unfortunately I have the Kubota quick attach so I have to design and build myself.
Pictures would help, but what is different between your Kubota quick attach and a tractor QA that takes skid steer attachments?
/ Building FEL hay spear, have a question #24
Thanks, Tex. I have seen adapters to fit that style:
Yes, that ^^^ is exactly my current setup.
Leaning towards two equal length spears about 30" apart, working on angled attachment plates to give me 15° of rollback.
/ Building FEL hay spear, have a question #26
That style is very similar to the global style,
I find the global much nicer to use then the SSQA and wish that more manufactures used or offered it.
Here is my final design. I have the bale spikes and sleeves, going to the fab shop monday to get started.
/ Building FEL hay spear, have a question #28
Just make sure your spread allows you to go into a pallet.
/ Building FEL hay spear, have a question #30
Looks like enough rollback :thumbsup:.
Now would be the time to build in a receiver hitch and chain slots. Also something at the top to mount a boom pole: fel boom pole - Google Search
The chain slots and receiver are visible on my brush fork frame:
Moving a trailer without getting off the seat to raise the jack:
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Bobcat S205 (A60462)
2022 John Deere Z930M (A57148)
2022 John Deere...
208320 (A58375)
208320 (A58375)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
