Structural engineers needed for a beam calculation.
/ Structural engineers needed for a beam calculation. #1
Woody65
Gold Member
East Northport and Oneonta NY
John Deere 4300 HST 4wd
I am planning on building a small bridge over a creek. About a 25’ span. Someone near me has 2 aluminum I beams for sale that are 25’ long, 8” width, 4” flange, .25 web and .35 flange width. I have searched for tables and or calculators that would give me the max load for this size beam to no avail. I only need a ballpark number to see if it is worth looking into. The bridge is only for personal use within my property for loads up to a 10k excavator. I know there are some qualified people on this site that can put me in the right direction. Thanks.
/ Structural engineers needed for a beam calculation. #2
The cheapest thing to do is buy an old flat bed tractor trailer, remove the bogies and landing gear, and use it for your bridge.
Been suggested before. No go. Have no way of getting it to the property, removing the axles or getting it near the creek it has to cross.
/ Structural engineers needed for a beam calculation. #6
What is strength of beams. Sounds small for excavaror
/ Structural engineers needed for a beam calculation. #8
I am planning on building a small bridge over a creek. About a 25 span. Someone near me has 2 aluminum I beams for sale that are 25 long, 8 width, 4 flange, .25 web and .35 flange width. I have searched for tables and or calculators that would give me the max load for this size beam to no avail. I only need a ballpark number to see if it is worth looking into. The bridge is only for personal use within my property for loads up to a 10k excavator. I know there are some qualified people on this site that can put me in the right direction. Thanks.
You need to find out the grade of the aluminum. You also need to determine the spacing of bracing for the compression flange. Unbraced beams will buckle if not accounted for with the applicable strength reductions. Should also check for local web yielding under a point load if applicable. This is rare in steel, but more possible with aluminum.
Concur with prior posts - these beams would most likely work for a garden tractor but not much more. The proposed equipment would be expected to overload the beams to the point of collapse - even if the material was steel. I have a pair of W10x68 x 30' long beams (2,000# each) which has a better chance of success.
Good Luck
Yooper Dave (WI PE)
/ Structural engineers needed for a beam calculation. #9
I doubt a licensed engineer will provide free advice. After all, that is how they earn their livelihood.
I am a mechanical engineer but let my license lapse decades ago. I could do the calculations but there is nothing but downside. I no longer have liability insurance and an error in calculations opens a professional engineer to a lawsuit.
Not what you want to hear...but reality.
A friend of mine who did free lance engineering on the side was sued when a wall collapsed. The contractor was finally found at fault but it was dicey for a while. My buddy never did another side job and focused on his corporate job.
Not asking for anyone to tell me what will work, just the load bearing off the beam. Geez???
/ Structural engineers needed for a beam calculation. #11
Don't walk away from the aluminum beams - run like the wind away from the beams.
Some one is going to get hurt.
Free of Charge
Yooper Dave
/ Structural engineers needed for a beam calculation. #13
it might be cheaper to put in a low water crossing and doing some excavating how deep is the creek? 25 feet is pretty short, i helped my neighbor put in a crossing on a creek that was about 20 foot across 8 foot deep, we excavated the banks down and make it very wide to make it work, have to usually do a little grading if we drive thru when wet or need to cross when its wet time of year, its not wet running creek yr round tho
/ Structural engineers needed for a beam calculation. #14
Strength of beam is based on it's material properties which you have not given. After strength is given, rating for beam can be given
/ Structural engineers needed for a beam calculation. #15
Free of Charge
Yooper Dave
I absolutely concur! (long ago civil engineer)
/ Structural engineers needed for a beam calculation. #16
As an engineer, I would be very hesitant to use an unknown aluminum I-Beam in this application. However, assuming the dimensions you have given are close to accurate, what you have are beams that conform to a standard 8 inch lightweight I-Beam in dimensions. For an I-Beam, the weight capacity is W=8fS/l where W is the weight capacity, f is the fiber stress (in psi), S is the section modulus (1.9 inch**3 for this beam) and l is the span in inches.
Let's say the beam was steel, with a 20,000 psi allowable fiber stress (typical for something like A36 steel) and the beam is 20 feet (240 inches) long. Then the allowable load is ((8 x 20,000 x 14.2)/240) =9467 lbs. Note that this is a distributed load, so for safety it should be reduced to 1/2, or a little over 4600 lbs. I have no idea what a reasonable allowable fiber stress is for aluminum but I would guess it's a good bit less than for steel. I couldn't immediately find values for aluminum to use for beam calculations but I would hesitate to put a ton of weight on these beams.
Bottom line is you are not going to get much capacity out of these beams. Note that all the above is simplified and assumes the beams are adequately braced to preclude buckling or other out of plane movement.
/ Structural engineers needed for a beam calculation. #17
I don't even need to run the math to know that an 8" aluminum i-beam isn't going to support much over a 25' span if it's a main beam.
/ Structural engineers needed for a beam calculation. #18
i will say this, 2 beams would not be advisable to haul much of anything across in my opinion regardless unless you had a very substantial platform - a friend and i rebuilt a country bridge that was abandonded and rotted through on a property we take care of, the one i referred to for the low water crossing - the other creek we rebuilt the bridge on, it is 14 feet span, 8 ft deep, it has 5 steel 10" ibeams sitting on a 1 foot ledge on concrete abutments. THey are at 2 ft spacing and we installed 5 inch thick creosote timbers across the ibeams.
I have no idea how much that would support but we drove my 10K lb skid steer on it and it didn't seem to even move entering/exiting/sitting in the middle - we also tied the timbers to the ibeams as well as then put driving treads on top of the timbers out of CCA
/ Structural engineers needed for a beam calculation. #19
I will give you a hint - You need to calculate the deflection to determine the safe working load. You are asking an engineering question with implied liabilities so not many people are going to put their neck on the chopping block for you on an anonymous user group. Hire a professional please and let them do the calcs. Safety first. If you dont know the answer then you probably shouldnt be doing the work.
I suggested the trailer because someone has already done the engineering for you.
/ Structural engineers needed for a beam calculation. #20
Exactly! Excellent Post.
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
Metal Goat Family Statues (A64127)
Metal Goat Family...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
2023 Kubota MX6000 (A64126)
2023 Kubota MX6000...
