Shed kit / installation issues
/ Shed kit / installation issues
I talked to the manager of Backyard Products in Denver. As expected, they offered to refund the cost of the floor upgrade (he didn't know exactly what that number was), plus a small amount to compensate for the inconvenience.
He said the other option is they can contact Engineering to see how they can tear it apart and redo the joists. It was assembled with a framing nailer and ring-shank nails. It's not going to come apart easily.
I told him I would call him back next week.
/ Shed kit / installation issues #23
If that's who is responsible for the warranty, I'd take it IF they allow you to fix it without voiding that warranty.
/ Shed kit / installation issues #24
Is that your shed in the photo? Fine looking shed.
/ Shed kit / installation issues #25
If you agree to settle for just the $150 that you paid but didn’t receive the agreed upon upgrade, you are then stuck with a shed you didn’t order, and aren’t happy with.
If it’s me, I get “pist” off thinking about it every time I walk past the thing.
No dice, take this thing back, and give me what I ordered.
Fortunately, you are dealing with Costco, a customer friendly outfit. Doubt if they will let you walk away unhappy with their service. You might decide whether you’re really happy with the first shed also, before you make the call.
This is not a case of you being a bad guy, it’s just getting what you paid for.
/ Shed kit / installation issues #26
You could also throw down another layer of flooring using construction adhesive and screws. That would certainly add enough strength.
/ Shed kit / installation issues #27
I would still call Costco and let them know. I had trouble with a TV bought at Costco, called the Concierge tech help, got things going, but then when they had to replace it since they could not fix it, I ended up talking to the shipper at one point, basically had to pick new TV up and return old one. Costco called a month later to see how things went, got pretty upset with shipper as Costco paid them for white glove, inside delivery, configure to work properly and remove old TV.. I should not have had to do anything. If you bought from Costco, give them a chance to make it right.
I like this idea. The difference between 16" OC and 12" OC over the span of 16' is 4x 2x4's.
The manager at Backyard Products offered to send down a guy to tear up the floor and rebuild it 12" OC, but I just don't even see how that could work. Even if it did "work", the guys that addressed the issues in the first shed had to beat it apart and made a mess of it. I don't think I want them trying to fix it.
Ultimately, it's the 3x 4x4's that are in contact with the shed pad. The 2x4's just distribute the weight. It seems to me I could put down 3/4" plywood (or something) to accomplish roughly the same thing, but I really don't know.
  • Shed floor.pdf
/ Shed kit / installation issues #29
How wide is this building? From the looks of that drawing it's the 4x4's which actually are supporting the weight. Seeing that I don't believe that the extra 2x4s will make that much of a difference. Negotiate a reasonable (in your favor) refund, or expect an all new shed if they decline.
/ Shed kit / installation issues #30
What is the going rate for competent labor in your area and compare that to the going rate for people who mess it up like they did for you.
About 5 years ago I could get poor quality carpentry work done and redone for about $10/hr, the good guys were $20/hr and booked for their lifetime.
If you figure the guy from Backyard Products was going to cost at least $250 (w/ overhead) PLUS travel they should foot the bill for GOOD plywood, if you install it.
And I mean pressure treated with minimal voids - not the cr@p from Lowes etc., that is 50% void on the onside. Or Advantech OSB SHEATHING.
The material will cost a lot more than a few 2x4's for but I would think it would give you a better floor.
/ Shed kit / installation issues #31
The difference between 12 and 16" OC would only be 3 or 4 if building fresh. To late for that. The only thing that would work would be to put 1 joist in between every joust so that would be many more, depending on the length.
Tipping it on the side would trash a nice shed by bending stuff and making it out of square.
If 16" is acceptable for heavy loads you may have, like a small tractor etc. then just get the refund for the upgrade and suck it up. If you think it will not be, I would not accept it no matter what. Have them redo it acceptably. The contractor just took the easy way out. He got paid for putting joists 12 OC and he made them 16 OC. Costco will make it good with tipping it on the side and having a lot of kindling from tearing up the floor.
/ Shed kit / installation issues #32
Yet if you have decent wood running perpendicular to the floor joists they will provide more support than those few extra 2x4s anyways.
Looking at his diagram I believe that he has it covered, depending on the width of the building. If not he still will accomplish more by adding more cross support than the original plan.
/ Shed kit / installation issues #33
If the floor upgrade make the shed 35% stronger, a refund of 35% (plus the 150.00) is in order.
I chatted with a very pleasant 1st-level manager (Meghan) at Costco this morning.
She listened to my ordeal. Tooks some photocopies and notes and had me e-mail her some pictures.
She said she would work with the next-level manager at Costco to contact Backyard Products.
So I guess we'll see.
Technically, all of the issues are related to the installation and the installation wasn't purchased through Costco.
(the process is to purchase installation directly from Backyard Products)
That's not a bad idea. Good thinking.
I suggested a couple options to Costco, including refunding BOTH $600 installation fees ($1200 total) in the form of either a Costco or Backyard Products credit.
We'll see. I feel like we spend a lot of money with Costco (and even more on the Costco Citibank VISA that was used to purchase these) annually and I'd like to think they take that sort of thing into consideration, but I don't know.
/ Shed kit / installation issues #36
I didn't know you could buy a building from a grocery store. Wouldn't that be like buying the Christmas Ham from a Lumber Yard?
/ Shed kit / installation issues #37
Why do you keep calling it a grocery store? It seems like they sell just about everything.
/ Shed kit / installation issues #39
I think you can buy hams at Menards! :thumbsup:
/ Shed kit / installation issues #40
He did it once. I did it once. I don't have that store here, but I would not shop at a place with a required membership fee, no matter what they sell.
Decorative Turtle Statue (A61569)
Decorative Turtle...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2019 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNFL0KG646154 (A61165)
2019 Ram 5500 4x4...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
