Rounded off drain plug
/ Rounded off drain plug
Lets not get ahead of ourselves now, we have to discuss the plan some more. There may be a better tool for the job. :D
Hammer an undersized socket on, weld it. Attach and weld breaker bar to socket. Weld pipe wrench to breaker bar. Then, finally, turn the tractor to loosen?
/ Rounded off drain plug #1,093
Close enough to a Rube Goldberg solution that I'll allow it... as long as at least one of the components is made by ACME.
/ Rounded off drain plug #1,094
/ Rounded off drain plug #1,095
Run cord from across the room for new light inside. If door doesn't shut, drill hole. Use outside flood light with motion detector on it. We don't want it to stay on all the time and heat the beer.
/ Rounded off drain plug #1,096
My wife wants to know why I have to check the internet 3 times a day. I HAVE TO SEE ABOUT THE DRAIN PLUG!
/ Rounded off drain plug #1,097
This is the easiest way...
1) remove exhaust pipe & steering wheel
2) Chock back wheels, put in neutral
3) drain gas & coolant
4) remove trans fill plug
5) have a keg party inviting 40 strong guys
6) after an hour or so...say "I bet we could flip that tractor upside down, up and backwards".
7) after draining, flip it back up.
/ Rounded off drain plug #1,098
Kando actually got it removed by the time we hit page three; but found the thread so entertaining that he didn't want to tell us.
/ Rounded off drain plug #1,099
You forgot to work a vice in there :laughing:
Iranch IRGC40 (A60463)
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
