Rounded off drain plug
/ Rounded off drain plug #981
Hereç—´ how hard a pipe wrench will bite. This same pipe wrench which is by no ones standard a quality tool and has buggered up teeth easily holds my weight turning against a floor jack axel. View attachment 582215View attachment 582216View attachment 582217
Those bottom jaw teeth certainly do look a bit rounded.
I sharpened the teeth on mine (formerly my dad's) with a triangular hand file.
Then gave them both to one of my sons.
I have a nice set of 3 aluminum Rigids for myself.
/ Rounded off drain plug #982
/ Rounded off drain plug #983
$50?
I got mine for free!
Plumber broke his, and left them by my boiler.
I sent them in to Klein, and got new ones for free.
I got the pipe wrench for free but I had to pay for both sets of Knipex pliers and the Klein adjustable wrench. I’ve got a Klein wrench that I bent the jaw on I should probably send back but then again it was my fault.
/ Rounded off drain plug #984
First thing would be to turn it over to the recommended position for tightening:
Less likley to break the adjustable jaw.
Then use a 3' long cheater pipe on it. :D
I didn’t have any pipe big enough to go over the adjustable wrench handle. I later swapped to a 12 point socket and breaker bar and drove the plug all the way in. I really figured that would do it in. Surprisingly that didn’t strip the head either.
/ Rounded off drain plug #986
For what you were doing there is really nothing for it to bottom out against. It makes you wonder why Kando's plug is jammed so badly, but I believe at some point he said that it may be cross threaded.
Over tightened. I always run the plug in by hand as far as I can before putting a wrench to it, so in theory there should be no way I cross threaded it.
/ Rounded off drain plug #988
LoL...All the post count trolls are about to pee their pants...!
/ Rounded off drain plug #989
On a different thread, some one said they didn't have a torque wrench, so they "tightened the nut down until they stripped the threads, and then backed off a quarter turn"
/ Rounded off drain plug #990
We're close!!!!!
This will help. I use black iron pipe and adapters for pipe wrench torque.
I store it on press, and it makes various lengths.
Two posts to go.View attachment 582272 20181208_185052.jpeg20181208_185116.jpeg
/ Rounded off drain plug #991
/ Rounded off drain plug #992
So do I get an award for the 1000th post?
/ Rounded off drain plug #993
Who痴 the post count trolls?
well it makes me a hypocrite but I was referring to all the posts that had everything to do with increasing the post count but nothing to do with the topic...
What will be interesting is what happens to the thread (afterwards) if/when Kando confesses to getting the plug out and posting some pics...!
/ Rounded off drain plug #994
Well I think this is the first time someone mentioned Lol along with peeing. Up until now we have only had serious posts in this thread. Always a joker in the bunch :rotfl:
/ Rounded off drain plug #995
You should have saved that for Kando. Now he will have to wait for post 2000.
/ Rounded off drain plug #996
You all couldn't help yourself and blew it. #1000 was reserved for Kando to share his triumph!
/ Rounded off drain plug #997
Pipe wrenches still have no replacement and I don稚 know what you have against them.
Firstly, I really don't have anything against pipe-wrenches per-se. They are bulky and unbalanced for the angle that Kando needs to get at the stripped drain plug though. He's tried a pipe-wrench without success.
Secondly, you yourself (in self-confessed boredom) have demonstrated that a vise-grip or a Knipex should 'do the job'. Both of those more 'modern' tools lock onto the rounded surface and are lighter and a heck of a lot less bulkier when it comes to manoeuvring it into position.
I, myself, don't own a pipe-wrench as my set of Aussie "Best-grip" perform the same function... plus I can use them in a number of different situations including a ratcheting motion without having the readjust the jaw.
/ Rounded off drain plug #998
The vice grip had the worst grip of the 3 and didn’t hold very long before coming off. It was also the shortest of the 3 tools so despite using the same test it had the least to live up to. I’m pretty sure if I had a big enough cheater pipe I could have twisted the floor jack axel off with the pipe wrench. The Knipex isn’t a very tough looking tool and really isn’t designed for cheater pipe action.
/ Rounded off drain plug #999
The vice grip had the worst grip of the 3 and didn’t hold very long before coming off. I’m pretty sure if I had a big enough cheater pipe I could have twisted the floor jack axel off with the pipe wrench. The Knipex isn’t a very tough looking tool and really isn’t designed for cheater pipe action.
That's fine.
As I said, my Aussie "Renovator" brand "Best Grip" (there are similar manufacturers out there) would work, is lighter and less bulkier plus could be used with a cheater. I'm not 'pushing' it as a be-all-to-end-all solution to Kando's problem but the tied-and-true, venerable, pipe-wrench has been tried and has not succeeded in his situation.
This thread, and many others on TBN, introduce new tools and products to many others.
/ Rounded off drain plug #1,000
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
BUSH HOG SBX72 - 72" BOX BLADE (A63291)
BUSH HOG SBX72 -...
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A61574)
2006 Freightliner...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
INTERNATIONAL 490 - 21' DISC HARROW (A63291)
INTERNATIONAL 490...
