B3000 HSDCC Heat
/ B3000 HSDCC Heat #1
TimP
Kingsville, MD
B3000HSDCC
Hi All.
I just got my used B3000 HSDCC delivered this week and was playing around with the heat controls.
I noticed that the air stream is pretty strong and its nice and warm... EXCEPT... for the right side vent.
It seems to be blowing cold air instead of warm air like the rest of the vents.
Is that Normal or is there some sort of problem with venting system that I need to check?
Thanks.
/ B3000 HSDCC Heat #2
Sounds like an issue.
/ B3000 HSDCC Heat #3
Do a search here, or on Google. Somewhere in my travels over the past year I read a discussion about this very issue.
I haven’t noticed any difference on my L4060.
/ B3000 HSDCC Heat #5
That was the discussion that I read.
/ B3000 HSDCC Heat
Based on that thread, it seems the cold air blowing is normal.
I sure wish those pictures were still there.... I am positive it would make things even more clear.
/ B3000 HSDCC Heat #7
On our B3030 cab model,the little side outlets will blow cold air and need to be turned off in winter.
The 3 front ball type outlets are warm.
Good Luck!
/ B3000 HSDCC Heat
Good Luck!
Hi number two !
Thanks for that info. I feel better now that I know it's, more or less, "normal" for the side vents to blow colder air than the other vents.
It's weird that the right side vent is colder than the left side, but it is what it is...…..
New/Unused Quick Attach Post Driver (A61166)
New/Unused Quick...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
UNUSED MINI HYD BACKHOE DIGGING ARM (A62130)
UNUSED MINI HYD...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
Hustler Super 104 104in. Zero Turn Commercial Mower (A61567)
Hustler Super 104...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
