Rounded off drain plug
/ Rounded off drain plug #483
Yah know fellas yah gots the right tools listed but you failed to include the right technician for Kandu!:eek:
OK which way to the drain plug???
OK, now what...I've used all the TBN recommended tools?!?!
/ Rounded off drain plug #484
/ Rounded off drain plug #485
This is as perplexing as removing a drain plug on a pallet.
/ Rounded off drain plug #487
Don't you guys have anything better to do....
Oh wait.....
/ Rounded off drain plug #489
have you tried clamping a vise tightly to it?.(put it on a floor jack) once clamped on, you should be able to turn the vise to loosen the nut, it has a much higher clamping force than what you have previously tried. if you know someone in your fire department, they may be able to get that loose with the "jaws of life", if it has clamping capability..
:applause: Since the rescue service will be there anyway from trying the first suggestion....:laughing:
/ Rounded off drain plug #490
have you tried clamping a vise tightly to it?.(put it on a floor jack) once clamped on, you should be able to turn the vise to loosen the nut, it has a much higher clamping force than what you have previously tried. if you know someone in your fire department, they may be able to get that loose with the "jaws of life", if it has clamping capability.. I need to say, that keeping bad oil, possibly with metal flakes in it, is not good at all for the transmission, that small amount on the bottom of the pan that you can't pump out will get stirred up!..
Radios1 has it wrong. Once you have the floor jack set, and the vice tightened on the drain plug, then you rotate the tractor.
/ Rounded off drain plug #491
No,no,no,once vise is securely tightened on drain plug,remove jack and take tractor into an open field(with vise hanging from plug)excelerate to full throttle in high gear THEN LOCK THE RIGHT HAND BRAKE. If that fail's,start slowly in a circle to the left,progressivly increase throttle and pressure on left hand brake until tractor is spinning lickity split counter-clockwise:hypnodisk: THEN quickly go from left brake to right brake:shocked: and hold on for dear life. Don't forget to wear your seatbelt.
/ Rounded off drain plug #493
using the vise would work safely, though!.. this thread is getting so absurd, I'm gone from it!..
With all due respect if there was room enough to use this suggestion, one of the other ideas would have gotten the job done months ago.
The crossbar directly under the plug limits the options. (I would have removed that bar long ago, and made something which either can be moved, or is offset so that you can get a wrench on the plug.
/ Rounded off drain plug #494
Wouldn't it be a hoot if for some odd reason that plug was a left handed thread and all this time he's been tightening it?
/ Rounded off drain plug #495
Or after he pumped out all the old fluid and refilled with fresh then the plug fell out.
/ Rounded off drain plug #496
While generally amusing, cannot believe I just went through 50 pages of posts for a drain bolt that has been stuck for 8 months! :duh:
/ Rounded off drain plug #497
And all the people that have keep on posting after his last post :dance1:
And all of the others that keep reading it :thumbsup:
/ Rounded off drain plug #498
Before you know it, there will be 500 posts to this thread!
/ Rounded off drain plug #500
HA,you should have been around when the farmer came here needing help with his donkeyl:donkey: with stopped up plumbing. A few suggestions were evil,a few down right inhumane and a bunch would be worth price of admission just to watch.:eek:
(2) 30 Yard Dumpsters (A61166)
(2) 30 Yard...
New Holland 3930 (A60462)
New Holland 3930...
2015 John Deere 8345RT Track Tractor (A63109)
2015 John Deere...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
2015 Ford F-250 Ext. Cab Auto Crane EHC-32 1.5 Ton Crane Service Truck (A61568)
2015 Ford F-250...
