Rounded off drain plug
/ Rounded off drain plug #461
Thanks for sharing. I just replaced our square head oil pan plug with the same NPT plug but with 11/16 hex head on our 1948 Model B Allis Chambers that we are rebuilding after Liquid Glass stop leak was ran in the crankcase.
It was $2.50 and in stock at NAPA.
/ Rounded off drain plug #462
I know a lot of people use mityvacs for engine oil and transmission oil change. Could that work here to get the old fluid out?
I've used my little HF $5 hand pump to take a half quart out of my VW when they vastly overfilled it.
Still on the back burner to do. In lieu of draining from the plug I've figured on using a pump to pull the trans oil out and just replace from there.
Excellent idea, keep us posted.
/ Rounded off drain plug #464
I see where this thread is going to be made into a pilot mini-series. Its just gonna be called - Plug. That's so it can cover almost all the discussion in this thread. Ha, ha, ha
/ Rounded off drain plug #465
So,,,,,, when you going to do that? :D :D
/ Rounded off drain plug #466
So, will this be the end of the story? That is, leave the plug in and just suction out whatever you can? Are there any further plans to remove the plug and is it now on a longer time frame bucket list?
I was kind of hoping to see this plug out of there.
I'd love to see the plug out, but it's something I probably won't be able to have done anytime soon short of sending it to a shop. I'm sure the threads would probably have to be redone too, although it may simply be a case of shear tight fit from having been overtightened.
/ Rounded off drain plug #468
I'd love to see the plug out, but it's something I probably won't be able to have done anytime soon short of sending it to a shop. ...
We'll keep a light on for ya ...
/ Rounded off drain plug #471
have you tried clamping a vise tightly to it?.(put it on a floor jack) once clamped on, you should be able to turn the vise to loosen the nut, it has a much higher clamping force than what you have previously tried. if you know someone in your fire department, they may be able to get that loose with the "jaws of life", if it has clamping capability.. I need to say, that keeping bad oil, possibly with metal flakes in it, is not good at all for the transmission, that small amount on the bottom of the pan that you can't pump out will get stirred up!..
/ Rounded off drain plug #472
:hissyfit: I think I got a broken foot just from reading that!
/ Rounded off drain plug #473
Yes, square head.
Here's the current state of the plug. That bar should be removable, bolt on each end. The loader mounts to the frame on the front under the engine and to axle on the rear, just a support bar I suppose. Johnkn, I've tried those extractors as well, although the one I tried was the one that fit in it's current state. Once I remove the bar I'll look into using the next size down, 1/2". Bolt head would normally be 9/16"
:eek: Horrible.
Look into Parrot Jaw Channel lock pliers.
channellock 41 - Google Search
... Maybe use a couple hose clamps to get a real good squeeze on the handle.​
/ Rounded off drain plug #475
:eek: Horrible.
Those won't work in Kando's case. He's got a super tight nut with rounded edges, very cramped space and has never done this before. Lots of things would work but he doesn't have the clearance or experience. Once he knocks this out or watches it done he's be able to do the next one in his sleep.
/ Rounded off drain plug #476
Sure looks that way. - A lot of insufficient strategies resulting in a cascade of degradation to the wrenching surface.
/ Rounded off drain plug #477
I would not screw with it...pun intended.
I never drained the oil on my 1999 Mercedes. Used a vacuum pump and sucked it out of the dip stick tube.
KISS
/ Rounded off drain plug #478
What a relief...I thought this thread had died!
/ Rounded off drain plug #479
Not yet. It will soon take second wind when Kando ask's how to retrieve a broken suction tube from inside.:laughing:
/ Rounded off drain plug #480
Retrieve suction tube? That's easy...
Step 1) Remove drain plug.
2025 32in. Tilting Bucket Mini Excavator Attachment (A61567)
2025 32in. Tilting...
2012 International (A59230)
2012 International...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2006 Miller Built Gooseneck Trailer (A63116)
2006 Miller Built...
2002 Sun Coast Trailers T/A 18ft Enclosed Trailer (A61569)
2002 Sun Coast...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
