Idea for a Bridge deck?
/ Idea for a Bridge deck? #42
Nice bridge. I think you should add wing walls before you backfill.
/ Idea for a Bridge deck? #44
Looks great. What are you going to do when the big logs for the main supports rot out, though?
/ Idea for a Bridge deck? #45
Nice bridge. I am going to begin a 20-24' bridge across a crevasse withing the next few months, hopefully. Maybe I will look to your pictures for ideas. I am thinking 10' wide.
/ Idea for a Bridge deck? #47
Get a flatbed semitrailer and pull that across after cutting off the landing gear and the wheels.
Aaron Z
The wood piece of the deck are easy to replace, the wood part under them are harder to replace, but they are in treated wood and they dont have a strong strutural role.
Thank, my bridge is 9 feet wide (just enouph for a pickup), I think this is a minimum.
Any reason why you didn't use treated wood for the deck?
Because it cheapper to put down three Hemlock tree cut them in 3 inch beam and threated myself with a brown stuff (or in fact by my wife!). ...But it take more time!
/ Idea for a Bridge deck? #53
I've seen old rail cars used as bridges. Also old van trailer frames.
You are right, the next bridge on that stream is an old van trailer, but I have not fund a proper size cheap one! So I made it with an old garage overhead steel frame... a lot more work!
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
