JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,057
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Couple of comments: I installed Bora brand spacers on my B2150 primarily for stability and roll-over prevention (comfort too) on steeper ground. Downside is that the belly mower is not compatible with spaced-out wheels. Very happy with the Bora spacers -- obviously well made and designed with every little detail in mind. There is definitely a big reason for spacers unrelated to chains if you work steep ground.
About chains, I view them as a last resort. With R4 tires if you do much snow removal you probably have no choice. As Fallon or someone said, try using just front chains first and see if you can get by with just them. (Timing not good since Garandman has already installed spacers but ...) My thinking is that front-only chains will handle most cases and not have to resort to the big rear chains. I have another B2150 in a different location (where there is a lot more snow) and in buying the second B2150 (an old used one) I came into a set of Ag tires (R1's) for it. I had already bought front chains but now with the R1's I have yet to put the chains on. Hel would freeze before I paid $500 for a set of chains.
I confess I do not have a repetitive day-in-day-out snow removal circumstance. In the area where I have the B2150 with R1 tires I typically arrive for a winter weekend, either have to use the 5ft snowblower (when I'm faced with 2 or 3 feet of packed snow) or else just a little loader or rear blade cleanup.
