Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,821
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
What I've done over the years as mine either stretched a bit or the tires have worn (probably both) is to use a bolt cutter to remove two links at a time in the side chains, between two cross chains. Once those are out, I replace them with a single screw type quick link. That shortens the side chain by one link.
If I ever need to lengthen the chains, it's simple to add another quick link.
I like that method of shortening ! Simple if you only need to remove less than a whole section which would be the case to take up wear with time.
FWIW this photo was in the instruction sheet for the set of OFA EKO8 front chains I bought this year. I had not seen it before in the two other rear chain sets I have.
gg
