Questions for the grapple guys
/ Questions for the grapple guys #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am considering getting a grapple and have started doing a little investigation. It appears there are a couple of basic styles of grapples, root rake brush grapples and open bottom style (so named on WR Long's website). The open bottom style appears to have a longer bottom jaw and looks like it would be superior at moving that jaw level into a pile of debris. The root rake styles looks like it would be superior at dropping down onto a pile of debris and then closing the jaws. Is that accurate, somewhat accurate, or totally inaccurate? I have never owned a grapple so just trying to look at all angles so as to hopefully make an informed decision.
I know the EA Wicked root grapple is very popular. I do like the fact that it is light weight. Based on my tractor size I am thinking their 55" version would be good for me.
/ Questions for the grapple guys #2
My first grapple was the root rake style, doesn't work well with large brush piles, but is better than no grapple.
My next grapple was the open bottom style, it will pick up a lot more brush. It also picks up everything else that I need to pick up. :thumbsup:
/ Questions for the grapple guys #3
I like the ones with the longer tines on the bottom. To me they seemed better on small brush piles as they rod on the times rather than having to be squeezed to stay in place.
/ Questions for the grapple guys #4
Pretty much the same here. I have 3 (wide rake, wide open bottom L, narrow open bottom L) grapples. If I had only had one, it would be the narrow open bottom L. Light weight is a priority on most CUTs and Utility tractors to increase lift. Many threads on this subject here on TBN to read up on. Lots of choices out there.
/ Questions for the grapple guys #5
Don't mean to hijack your thread but my primary use would be picking up rocks. What style grapple would you suggest for that?
/ Questions for the grapple guys #6
OP: One suggestion is for you to call Travis at EA, discuss with Travis your applications for a grapple, and get his advice. I have found Travis to be very helpful. We have two grapples (one is a 56" W. R. Long OBG2 "open bottom" model, and the other is the same style but 48" and with a single cylinder). Our grapples are like the EA grapple that is described as a "root grapple" (as contrasted with the EA "root rake grapple"). Like the other posters, I like ours for their versatility and have never wished for a root-rake style grapple.
/ Questions for the grapple guys #7
I've had my Land Pride SGC1560 - rock & root grapple now for four years. Its very heavy duty - 820# - and does exactly what I need. I move large rocks and large Ponderosa pine logs. Essentially - I have NO brush on my 80 acres - no need for a brush grapple.
/ Questions for the grapple guys #8
I dig out and pick up a lot of rocks with the open bottom style, also called the L bottom style:
/ Questions for the grapple guys #9
View attachment 570146View attachment 570147 OK - my grapple and another item you should consider. Modifying your OEM grill guard to protect your grill, radiator, battery etc, etc.
See how Xfaxman sort of "comes down" on the rocks. That's the way I've found to work the best also. Scooping forward with the bottom tines scarfing the ground - most times will result in quite a bit of sod and dirt gathered also. Not what I want. I will rotate the grapple until its pointing almost straight down - open the jaws - come down on the rock or chunk of pine log - close the grapple - lift and rotate the grapple to the full upright position - if I'm going any distance. Otherwise - leave the grapple pointed down and move whatever I've got in the jaws to somewhere else.
/ Questions for the grapple guys #10
Here is the L Bottom style picking up a large rock, mostly below ground level:
Put the bottom tines against it and popped it up:
Slid the bottom tines under, clamped and picked it up:
Curled up and opened the lids:
/ Questions for the grapple guys #11
Here is my rock bucket with grapple. And I second the vote on picking up the rocks from above instead of scouping them up. IMG_1631.JPG
/ Questions for the grapple guys #12
There are many styles of grapples. I would not choose a brush grapple to pick rocks. As you can see the L-style that Xfaxman uses works great - so does the rock & root grapple I use. Different strokes - etc, etc. JMHO - but, its not so much the exact type of grapple that will make a good rock grapple - its more the skill and experience of the operator.
Do not forget - the purchase of the grapple is only part of the overall cost. You must also get hydraulic power to the grapple one way or the other.
What is the best grapple for you - TomIre - what fits your tractor and pocket book best. Remember - you are talking about the purchase of an implement that with proper use and maintenance should be expected to last a lifetime.
Example - my grapple that I'm talking about in post #7 & #9. The WR Long hydraulic over electric activation system - $1195 The Land Pride SGC1560 grapple - #3175 This is the price of the equipment plus installation.
/ Questions for the grapple guys #13
I have the Land Pride SCG1572 and it has no problem with brush. Either ripping it out or moving it
Andy
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
JOHN DEERE HX 14' ROTARY MOWER (A63291)
JOHN DEERE HX 14'...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
