Using a metal snake on ABS plastic drain pipe?
/ Using a metal snake on ABS plastic drain pipe?
$4.59 plus tax!!!
/ Using a metal snake on ABS plastic drain pipe? #42
I have an assortment of drain tools...
Don't overlook the lowly Balloon.... it expands and vibrates and clears most anything... sometimes even a hose alone will work.
I find going down the vent pipe on the roof is very successful after going the plunging route.
For Roots or things put in pipe like grease, or hygiene products or swifter type things... I have to go to my cable rooter with various heads... have a handheld with 35' reach and a drum that will max out at 215'
/ Using a metal snake on ABS plastic drain pipe? #43
I always start off trying the pull back plunger method Mossroad suggested. If that doesn't work, I usually find the clog in the first few feet of the drain. For some odd reason, I think my shaving cream builds up in the tail pipe of my bathroom sink just before the trap. Maybe the trap slows the velocity of the drain water and allows the shaving cream time to stick to the tail pipe.
My other usual suspect areas are the bend in the trap, the line running into the wall, and the 90 degree transition in the wall. Many of the older houses had 90 degree fittings here instead of sweep transitions that have better water flow.
I doubt that the blockage was in the ABS pipe in your other photo.
/ Using a metal snake on ABS plastic drain pipe? #45
Have had a lot more problems since water saving aerators were mandated for bathroom sinks...
People hardly let any water flow, and what does flow is often cold... never getting really hot.
A work, after hours once a week I let the hot water flow at the sinks for 10 minutes... have not had a slow drain in over two years since doing this... the soap, etc... just builds up.
I also like to use drain care... it is slow acting enzyme to nibble away organics... works much better warm surfaces than cold...
Trouble again!
The sink was backing up again this morning. Not nearly as bad as before, but holding maybe 2" in the bowl while the water was running.
Here is the weird part. I watched it slowly drain after shutting off the faucet. It drained until the water level in the drain was about level with the bottom of the sink. It stopped and held that level for a few seconds with no movement. Then, on its own, whoosh it drained. I did this twice in a row. Once the water is drained down to the P-trap, I then hear glug-glug-glug-glug-glug about 10 times or so. Is this maybe also a venting issue?
Do I need a plumber, or a witch doctor to remove the spell???????????
/ Using a metal snake on ABS plastic drain pipe? #47
Most likely hair... and when the force of the water is enough... the hair gives and the water flows.
/ Using a metal snake on ABS plastic drain pipe? #48
Critters do get into the vents from the roof and do cause problems. Likely a issue. Depends on length of drain lines, location of vents in them, just for starters. Just have to run cable down the vents and see. Plunger also might keep working stuff loose in the drain lines as time goes by.
/ Using a metal snake on ABS plastic drain pipe? #49
A lot can be done with a simple garden hose and a rag... helps to have a spotter just in case the water ends up going somewhere you don't want it to.
My Spartan Cable Rooter was about 3k when it was all said an done... use it several times a month and bill owners when I do...
Seemed a waste to wait for the Rooter guy to show up when I could do it myself if I had the equipment...
The handheld job with 35' of cable cost about $500 but has also made me money...
Before that, it was the hose and balloon...
Critters do get into the vents from the roof and do cause problems. Just have to run cable down the vents and see.
The roof is at least 12-12 pitch, maybe steeper. So I'm not exactly sure how to (safely) get to the vent. I don't have a boom truck lol. If I can get to the vent, what do I do then? Could I run an electrical fish tape down it looking for an obstruction?
btw my house is an old 1800s farm house. Remodeled many times, in 1946, also in 1970. Seems I need to fix almost everything ... constantly!
My wife said the sink in the basement also goes glug-glug-glug after the water goes down the drain.
I looked at it again with a powerful flashlight. Yes it does run horizontally to a 90 degree galvanized elbow that turns down. I don't see any pipe that could be venting anywhere. Could that vent pipe connect in somewhere else down the line? If there was no vent at all, how would the sink drain behave?
/ Using a metal snake on ABS plastic drain pipe? #54
Glug glug sounds are from the system trying to breathe. The first thing I would check is the flow from the house into the septic tank. There should be an inspection cap on the pipe between the house and tank.
There should be no standing water in that pipe. Flush a toilet and you should see the water flow through.
The tank vents through the house risers and if the tank is overfull meaning it is not draining into the field properly, the house outlet pipe remains full of water.
Then nothing can vent.
No vent, no water flow, leads to clogs and eventually sewage backing up into the house.
You can also call for a septic service and have them check the flow from the house.
I had the septic system checked and pumped two years ago. With just my wife and I in the house I suspect the tank is not an issue but as you suggest I will check it. I think I need to check venting also anyway I can.
/ Using a metal snake on ABS plastic drain pipe? #56
If it turns out to be a vent issue.
It’s a pain but if you have to, the vent pipes might be easier to access from in the attic. Lay down a smallish piece of plywood or board on top of the joists if needed in your work area to stand on. Cut the pipe, do your work and use a rubber coupling to splice back. Or if its plastic pipe you could glue in a new coupling.
/ Using a metal snake on ABS plastic drain pipe? #57
Trouble again!
It may be that you were able to loosen the obstruction enough to get water to slowly drain when you used the plunger, but it is still inside the pipe. Although a plunger can loosen stuff, I've never been able to remove built up crud in the pipes without taking the trap apart and running something like that plastic zip tool or an electrian's fish tape in the pipe to pull out the crud.
You also mentioned glug, glug, glug in another post and that you have an older home that has been remodeled. Although you don't have to have a vent pipe right at the sink, the drain system does need air to drain. If the drain used to work okay before, my guess is you still have an obstruction in the drain line. All the vent air in the world won't compensate for a lump of crud in the drain line.
My thought for now is to stay off the roof and try to see you can pull out any obstruction in your drain that's not draining.
You can buy a USB snake camera on ebay for about $10 that has a built in light if you want to try to see what's inside the pipe. Occasionally handy for looking inside walls or car repairs, too.
/ Using a metal snake on ABS plastic drain pipe? #58
/ Using a metal snake on ABS plastic drain pipe? #59
I'm finding that out as I go.... low flow is great for water conservation, but it doesn't move enough water down the drains to clear the pipes. Just wait until you have to install low flow flush valves in urinals and the urine crystallizes in the pipes to eventual blockage. The snake doesn't clear it and the pipes have to be opened. I've seen it a couple times already, and days like that, I'm glad I'm not a plumber! :p
/ Using a metal snake on ABS plastic drain pipe? #60
^^^ Low Flow was the mandate for toilets and urinals here when we built in 1995... there have been challenges and often it takes two Royal Flush flushes to clear a toilet.
I had an elderly renter that was the worst when it came to clogged sinks... she simply did not let any water flow... I was in their every 3 months... when she moved... not another call... simply not enough flow to flush the waste line.
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
Caterpillar 325/325L/325LN Excavator Service and Parts Manuals (A63117)
Caterpillar...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
