Subsoiler for Yanking Rocks?
/ Subsoiler for Yanking Rocks? #21
A rock battle can never be won. There are just too many and the numbers never diminish. One a good day you might break even.
I no longer turn my fields over. When I did, a rock picker kept the battle even, w/ patience and multiple passes. A backhoe is necessary for the enormous culprits. There are some in my fields that were too big to remove, and if I got them out, then what?
I simply dug a 8 ft deep hole right next to them and used the hoe to send them on their way. Subsoil and topsoil back on top RIP.
What I did was get out the occasion giant rock that was in the way. That worked. Then I got a 6' wide rototiller and just skimmed the surface without bringing up more rocks. Till extra slow, leave the rear lid down and it works. I seeded beautiful and smooth fields this way and minimal rocks surfaced, even though there were many beneath the surface. After tilling it needs to be rolled or packed to press any rock edges down.
I ended up ordering a small, reversible subsoiler. If it will lift a 300-pound rock up to where I can get it with the loader, it will be better than gold.
/ Subsoiler for Yanking Rocks? #23
The scarifier would be fine for a few big rocks that you know are there. My soil is *full* of rocks, of all sizes. The BB with scarifiers finds them and pops them and collects them--anything approx egg size, up to approx chicken size. :)
Of course you never win the war on rocks, but on newly graded soil where you plan to plant grass, it won't grow over a rock, plus if you mow your blades will eventually hit the rocks. So it helps to remove the rocks from the top 3-4 inches of soil. Then, once the grass is established, the sod does help keep more rocks from popping up due to frost/thaw. I also did this in the garden.
Most old farms here have a huge mountain of rocks somewhere on the property; probably the farmer laboriously picked them up by hand after plowing (suspect this was the kids' job; no wonder they all left :) ) over many years.
I ordered a subsoiler, and I picked it up a couple of days ago. I put it on the tractor and hooked up on the rock. It would not budge. It was probably hung up on a root and whatever rocks were down there with it. I turned the tractor 90 degrees and tried again, and the rock came right out.
Fortunately, I had two large guys here with me. They rolled the tractor into the bucket, and now it's part of my collection of big landscaping rocks. The bucket groaned a bit. Heavy rock.
I would say it's about 30" wide and 20" across.
I didn't turn the subsoiler around to face forward because I was lazy. This made it harder to disengage once the rock was out.
Thanks for all the great information.
Interesting fact about the subsoiler: the shear bolt appears to be metric. I busted it on a stump, and when I compared it to imperial bolts, it was somewhere between 7/8" and 1/2".
/ Subsoiler for Yanking Rocks? #26
What are the markings on the head of the bolt?
/ Subsoiler for Yanking Rocks? #27
I bought a stump bucket to dig out a few stumps that were in the way and found that it's very good at digging out rocks also. Just drive up to the rock, put the bucket in front of it, dig, and then move it to where you want. I use it for rocks more than stumps!
The bolt head has these marks on it: "SC" and "BB."
I don't know what a stump bucket is, but it sounds great. I'm going to look it up.
More rocks. This thing is a blast.
/ Subsoiler for Yanking Rocks? #30
I recall having one with a 9/16" or 5/8" grade 2 shear bolt in it. That's what I think you have.
Pulling rocks is fun if you have soil to put in the hole and a place to put the rocks. City people will pay for rocks and I've sold tons.
This bolt has a shaft about 0.470" in diameter. Don't know the thread major diameter.
I don't think it matters. It's so close to 7/16", I'm not worried about it.
I see I said 7/8" in my earlier post. Brain flatulence at work. I meant 7/16".
/ Subsoiler for Yanking Rocks? #32
Sure looks like you're having fun pulling rocks. 7/16" is a pretty small shear bolt. I would use whatever shear bolt fits the tightest. Sometimes, a very slightly looser fit will shear easier than the correct size.
It could very well be metric and the maker of the unit will have that info. Dealers tend to guess while the maker knows for sure. Shear bolts are worth getting the right ones.
/ Subsoiler for Yanking Rocks? #33
I have a big 'ol single bottom Pittsburg moldboard plow. I can strip everything off and just have a VERY heavy shank remaining. If its down there the Pittsburg will find it. I use the moldboard shank if I want to go 12" to 14" deep. Otherwise I can use the shanks on either my Bush Hog ROBB or Land Pride LPGS - if I want to scarify shallow.
Experience has shown me - no need to scarify - there are plenty of rocks, right on the surface. I don't need to be dredging more up.
/ Subsoiler for Yanking Rocks? #34
12mm = .472" so I would say it is a 12mm and the thread pitch could be 1, 1.25, 1.5, 1.75mm
7/16 = .437"
I completely forgot that a manual came with this thing. The bolt is M12 x 85mm.
/ Subsoiler for Yanking Rocks? #36
Sub-soilers will pull up rocks. And roots. And buried wires and pipes.
I was using a subsoiler to trench for an invisible fence. Things were going swimmingly. After laying wire and working my way around, I looked back and saw that I had somehow pulled about about 75 yards of the wire I had just laid.
/ Subsoiler for Yanking Rocks? #37
Find out the grade and get a few more with nuts and washers. I write what they are for on the side of the bolt with a Sharpie marker since shear bolts are hard to find when you need them.
/ Subsoiler for Yanking Rocks? #38
One of the best lines I ever heard on the TBN was calling a single shank ripper by its proper name:
Utility Line Locator, Non-Discriminating
That's exactly what it is and better be 100% sure where everything is underground. Old timers liked to run electric to outbuildings by going just a few inches underground.
/ Subsoiler for Yanking Rocks? #39
^^^Yeah, no kidding!
/ Subsoiler for Yanking Rocks? #40
That doesnt narrow things down much. Backhoes fit that bill just as well. Box blades to a lesser degree.
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2021 John Deere 5230L Applicator (A63109)
2021 John Deere...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2016 Chevrolet...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
