MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,983
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
Calculating the bearing life is not so simple as looking at the basic load rating. Part of the life equation (revolutions) is a factor of (dynamic load rating/equivalent load)cubed. If the bearing load is the rated dynamic load, this factor is simple - one. If the bearing load is one half of the rated load the life will be 2 cubed or 8 times longer than if running at rated load. Now drive on a side slope and thrust load is added and these bearings are not designed for high thrust loads. Life calculations get very complicated as an example I had the load histogram taken from field test data for a drive. Bearing life was the critical parameter. I gave the histogram data in percentage time at given loads having broke my data into 30 different load ranges. When looking at the computer generated results, only the 3 highest loads were significant. Combined they represented only 5% of the operating life but that cube factor becomes so significant. Yes I run my tractor hard. Bearing life was a concern do I routinely loosed for leaks. I had hoped for better but I am not extremely disappointed with my bearing failure.
