Now ready for the concrete in the pole barn
   / Now ready for the concrete in the pole barn #51
The walls are 16'. Easier and cheaper to run the conduit under the slab to reach the other side. Will take to much wire to go up a 16' wall then across the trusses and then back down 12' on the other wall. Not a fan of having all that romex exposed.
I went the conduit and up/over route- I would argue much easier to expand and or troubleshoot than buried but to each his own Image1534425939.602945.jpgImage1534426017.419790.jpg
   / Now ready for the concrete in the pole barn #52
I'm confused again. Are you installing radiant floor heating in a building without an attic or ceiling? How will you insulate the roof area to take advantage of the radiant floor heating?
   / Now ready for the concrete in the pole barn #54
No I think we drifted and the OP allowed it. :)
All stoned in on the outside. Installed sink drain and electical conduit for rv 50 amp service. Only conduit I will put under the slab. Since I am building a loft in the back I will use the floor joist to run the conduit to the other side.20180816_093208.jpeg20180816_134257.jpeg20180816_155745.jpeg20180816_165629.jpeg
No...that was someone elses pic showing his radiant job. That would be a budget buster for me !!
   / Now ready for the concrete in the pole barn #58
Agree, very nice looking conduit. It even looks hard piped commercial. Nice.
   / Now ready for the concrete in the pole barn #59
It is commercial-decided that the cost differential wasn’t significant enough not to step up
   / Now ready for the concrete in the pole barn #60
Well, you will never have a problem with it, well protected. Well worth it.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2019 Harley Davidson 114 Police (A50324)
2019 Harley...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
