Now ready for the concrete in the pole barn
   / Now ready for the concrete in the pole barn #51
The walls are 16'. Easier and cheaper to run the conduit under the slab to reach the other side. Will take to much wire to go up a 16' wall then across the trusses and then back down 12' on the other wall. Not a fan of having all that romex exposed.
I went the conduit and up/over route- I would argue much easier to expand and or troubleshoot than buried but to each his own Image1534425939.602945.jpgImage1534426017.419790.jpg
   / Now ready for the concrete in the pole barn #52
I'm confused again. Are you installing radiant floor heating in a building without an attic or ceiling? How will you insulate the roof area to take advantage of the radiant floor heating?
   / Now ready for the concrete in the pole barn #54
No I think we drifted and the OP allowed it. :)
All stoned in on the outside. Installed sink drain and electical conduit for rv 50 amp service. Only conduit I will put under the slab. Since I am building a loft in the back I will use the floor joist to run the conduit to the other side.20180816_093208.jpeg20180816_134257.jpeg20180816_155745.jpeg20180816_165629.jpeg
No...that was someone elses pic showing his radiant job. That would be a budget buster for me !!
   / Now ready for the concrete in the pole barn #58
Agree, very nice looking conduit. It even looks hard piped commercial. Nice.
   / Now ready for the concrete in the pole barn #59
It is commercial-decided that the cost differential wasn’t significant enough not to step up
   / Now ready for the concrete in the pole barn #60
Well, you will never have a problem with it, well protected. Well worth it.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Step Ladder (A47477)
Famall Cub Tractor (NOT RUNNING) (A50775)
Famall Cub Tractor...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
