Compact tractor Fatality
/ Compact tractor Fatality #1
majorwager
western new york
kubota mx 5100 IH 484 ford 1620 lull 844b
Screenshot below contains current details available
/ Compact tractor Fatality #2
That's too bad for the guy. I wonder if he drilled a bootleg hole in his ROPS?
/ Compact tractor Fatality #3
^^^^All things considered, that's a rather callous comment.
/ Compact tractor Fatality #4
Indeed a shame...RIP.
/ Compact tractor Fatality #5
RIP, sad news. no details on why the ROPS failed, it seems inconceivable the ROPS didn't save him..
/ Compact tractor Fatality #6
^^^^^ It may not have failed per se, just not been enough to protect him. The tractor may have rolled against a rock or tree, or he could have been thrown free if he wasn't wearing his seatbelt. It doesn't really matter, the results are the same. RIP Mr Moran.
/ Compact tractor Fatality #7
Agree. No sense at all with armchair analysis, particularly when not knowing any of the details and jumping to conclusions. :confused3:
/ Compact tractor Fatality #9
Seems like we do not know if the tractor had a ROPS. Maybe it did not.
We also do not know if he was using his seat belt if it did have a ROPS.
MESSAGE to us should be to use what safety gear our tractors have, at all times.
Be interesting to know more details...
Bill
/ Compact tractor Fatality #10
A few years back I stopped to help an elderly couple who had gotten into some kind of trouble with equipment in difficult terrain. I could see their setup for recovery was sketchy and stopped to help.
Just because someone has Rural property doesn't make them a good candidate for operating equipment.
/ Compact tractor Fatality #11
Bill
I brought up that subject, and no-one cares how it happened, even though it could save lives:shocked: it's probably better to leave it mysterious here!..
/ Compact tractor Fatality #12
ROPS in use = wear seat belt
ROPS not in use = do not wear seat belt
/ Compact tractor Fatality #13
If your on a slick hill, put it in 4x4 and lock the diff. Some tires are slick on wet grass and they have zero traction sliding sideways. There should be more awareness and videos to educate tractor owners on these issues.
/ Compact tractor Fatality #14
My friend actually survived a similar situation after doing what most would say everything wrong. He was driving his new BX in 2wd down a *steep* concrete drive with the bucket full of dirt, no ballast box, rops up, and no seatbelt. Naturally the rear of the tractor was light, began skidding, accelerated, raised up on the pivoting front axle, tipped over and slid down to the bottom. He said it happened in an instant and jumped away just before it rolled. The roll bar was completely bent over to below seat height.
/ Compact tractor Fatality #15
that's insane, a rops should NEVER be compromised!. there's no sense in having one if it can't protect you!. something similar is used in race cars going over 200 MPH, and they don't fail..
/ Compact tractor Fatality #16
It was folded or bent in the crash?
/ Compact tractor Fatality #17
News reports are notoriously inaccurate. It's not an accident investigation. People come to all kinds of conclusions!
A ROPS must have some kind of certification to represent some standard of safety. Otherwise, I'm sure off shore manufacturers would build them to look solid but out of soup can material.
I would have no problem welding onto a rops, and drilling enough holes into it to make it look like swiss cheese, I am sure it would still perform it's function, just no longer be certified.
We are not talking about a D10 for crying out loud! Some people just don't get stuff like that, clearly!
Deerherd.
Since there is interest in the circumstances, I am submitting a FOIL request to the Undersheriff to obtain the report. I spoke to the Fire Chief but he was unable to comment.
If the details cause others to THINK before acting, something positive may arise from a tragedy. Will post the results. I am the OP.
/ Compact tractor Fatality #19
ROPs is only Roll Over Protection, not a substantial higher speed crash cage.
/ Compact tractor Fatality #20
Not only that, but most are rated for the mass of the base tractor. Mine is. Then you add 1,800 lbs of FEL and BH, and technically it's undersized.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
2016 CARGO CRAFT 16 FOOT ENCLOSED TRAILER (A67714)
2016 CARGO CRAFT...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
SHOP BUILT MINI VAC TRAILER (INOPERABLE) (A67714)
SHOP BUILT MINI...
PORTA POTTY (A67714)
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
