12 VDC Transfer pump for small tank
   / 12 VDC Transfer pump for small tank #1
ustmd
Manor, TX (outside of Austin)
Kioti CK27 HST
We have a "remote" pasture that we sometimes but the horses in. For a number of reasons, I can not run a water line to it.
The wife and FiL have been filling the 100 gallon water tank using a 35 gallon transfer tank in the back of the UTV. They have been gravity feeding the trough from the tank in the back of the UTV. Obviously, this takes forever.
I am wondering if getting a small 12 VDC transfer pump would speed the process?
If so, are there any recommendations?
   / 12 VDC Transfer pump for small tank #2
I would think any small continuous 35gpm 12V pump would work. $40-50 bucks..
   / 12 VDC Transfer pump for small tank #3
I guess it depends upon how long it takes the transfer tank to drain down by gravity and how much you want to spend on a transfer pump. I see that a complete 12 V setup starts at around $60 and they go up from there.
I've never used a small unit. I've got a big 'ol 4" gas powered trash pump that will fill a 1000 gallon tank before you can find a good place to sit down.
   / 12 VDC Transfer pump for small tank #4
How long is it taking to drain the tank via gravity? $40 pump from hf should do it in like 10 min. Seems like you need a bigger transfer tank.....
   / 12 VDC Transfer pump for small tank #5
YUP!!
Manual Aluminum 16ft Man Lift (A57454)
Manual Aluminum...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2012 Dodge Grand Caravan Van (A56859)
2012 Dodge Grand...
2001 New Holland TN75 Farm Tractor (A57453)
2001 New Holland...
