LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,321
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Really excited to finally get everything set up. Figured I would share my setup with everyone. Using a portable generator to back feed panel. Safety panel interlocks in place!
Total cost right at $2,570
I often loose power due to living so far out in the country. Until now I have had to run extension cords through the house and used a 3,050 watt generator to power an AC window unit, WiFi, fridge/ freezer, deep freezer, phone chargers. Real pain to run all the cords and all that.
So to solve all this I purchased a Champion 9,200 watt ( model 100110) generator, 2 Geninterlock.com interlocks ( specific to needs), 2 extension cords,One for 50 amp house feed, one for 30 amp for shop/ apartment over shop.
Generator $1000 Lowe’s
Electrical work $1000
Generator interlocks $69 and $64 plus shipping
50 amp 10’ cord and inlet box $160
Inlet box for shop $43
30 amp 100’ cord for generator to shop/ apartment $180
Power back alarm $45
The generator interlocks are the most important part of the setup IMO. This setup requires a 2 pole 50 amp breaker to be placed in the breaker box. The interlock kit makes it impossible to have both the main breaker and generator breaker on at the same time. It will only allow one or the other at a time. This prevents the generator for back feeding the main power lines or the generator and main line both attempting to power the house at the same time.
I did have to replace my electric water heater with natural gas so that I could free up 2 poles in my breaker box. That was extra cost but not required by most folks.
So, power goes out, I turn on the power back alarm ( notices me when main line is reenergized) and turn off the main breaker and all other breakers off.... go to garage and plug up house side of extension cord and thread the collar onto the inlet box so it can’t be pulled out. Plug the other bed into generator. Next I start generator and go back to breaker box. I double check the main is off, slide the interlock over and turn the generator breaker on. I then turn on all 110 breakers one at a time with a pause between them to allow the generator to recover for items coming on line.
I walked my wife through setup and break down of this tonight. I also printed off instructions.
I will have to add instructions for running the 100’ cord across to the inlet box on shop. It will allow me to power the apartment over the shop for my renter.
The champion 9,200 watt is a beast for less than $1000! I turned on every light in the house, 4 ceiling fans, 1 deep freezer, 1 fridge/ freezer, 1 110 window unit, one large eye on cook top, and 1,000 watt microwave and was only pulling 3 to 5 power bars of the 7 available. I consider this to be a overall great investment. Will make life much easer!
I do plan to get a 30 gallon drum to store fuel in. Every 6 months I will fill my truck up from the drum and refill it with fresh fuel.
Parts list
Generator
9200-Running-Watt Portable Generator with Engine Shop Champion Power Equipment 92-Running-Watt Portable Generator with Engine at Lowes.com
Power back alarm
Reliance Controls Corporation THP108... Amazon.com: Reliance Controls Corporation THP18 PowerBACK! Mains Return Alarm: Home Improvement
50 amp 10’ power cord and inlet
Conntek GIB1450-015 50 Amp... Amazon.com: Conntek GIB145-15 5 Amp DUO-RainSeal Kit NEMA 14-5P 4 Prong Temporary Power Cord with Inlet Box, 15': Garden & Outdoor
Shop 30 amp inlet box ( bought on amazon)
30 Amp Generator Inlet Box, AI-PB30 Power Cord Twist Lock Receptacle | eBay
30amp 100’ cord for shop to generator at house
L14-3 Generator Extension Cords
Generator interlock site
https://www.geninterlock.com
Nice setup, just having it will act as insurance as has been said.
Looks like you have Millington TN as your home area, I spent most of year down there back in 1971 at Millington Navel Air Station going to Avionic school, enjoyed the area.
At that time if I headed east and northerly the county got rural rapidly.
