48 loader on a jd3020 gas model
/ 48 loader on a jd3020 gas model #1
dvaidm
Member
Harding mn
3020 john deere and 50 john deere
I have a John Deere 3020 gas model. It has a loader 48 on it. Today the loader controls or something went haywire cuz I use the bucket control to tip it forward and it wouldn't tip back and I raise the loader and the loader would not go down let me rephrase that the loader did go down when I had it in the down position but it took a long time for it to go down any recommendations it has fluid hydraulic fluid.?
/ 48 loader on a jd3020 gas model #2
What type valve control FEL(scv or ind)? Are any quick disconnect hyd fittings involved with FEL? If so disconnect/reconnect each set to be sure they're seating properly.
/ 48 loader on a jd3020 gas model #3
Agree with Tx Jim.
Have you removed and reconnected any hoses, replaced a couple of hoses? A hose or two in the wrong valve ports can cause what you are experiencing.
Add anything hydraulic like a grapple?
Post some photos of the valve and hoses and then the overall tractor.
Dave m7040
Agree with Tx Jim.
Dave m7040
No I haven't removed any of the hoses
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
YALE FORKLIFT (A63291)
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
