48 loader on a jd3020 gas model
   / 48 loader on a jd3020 gas model #1
dvaidm
Harding mn
3020 john deere and 50 john deere
I have a John Deere 3020 gas model. It has a loader 48 on it. Today the loader controls or something went haywire cuz I use the bucket control to tip it forward and it wouldn't tip back and I raise the loader and the loader would not go down let me rephrase that the loader did go down when I had it in the down position but it took a long time for it to go down any recommendations it has fluid hydraulic fluid.?
   / 48 loader on a jd3020 gas model #2
What type valve control FEL(scv or ind)? Are any quick disconnect hyd fittings involved with FEL? If so disconnect/reconnect each set to be sure they're seating properly.
   / 48 loader on a jd3020 gas model #3
Agree with Tx Jim.
Have you removed and reconnected any hoses, replaced a couple of hoses? A hose or two in the wrong valve ports can cause what you are experiencing.
Add anything hydraulic like a grapple?
Post some photos of the valve and hoses and then the overall tractor.
Dave m7040
Agree with Tx Jim.
Dave m7040
No I haven't removed any of the hoses
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
Wilrich Field Cultivator (A50515)
Wilrich Field...
